1k Spindle (1.0K-55HP-A1-20)
Product Image
GET QUOTE
1000-rpm Spindle
    CNY ONLY
Standard spindle for the ST-55
  • 1k speed
  • A1-20 nose
  • 55 hp power
  • Gearbox drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This high-torque spindle features twin-chuck capability, a 2-speed gearbox, and a 12.5" through-bore, making it ideal for machining heavy pipes and fittings, large couplers, and long rollers.
  • Ideal for oilfield pipe machining
  • Extra-large spindle bore to swallow large parts or pipe
  • Massive spindle bearings for extreme rigidity
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
