15k Spindle (15K-40T-IN)
Product Image
GET QUOTE
15,000-rpm Spindle
    CNY ONLY
High-speed spindle for 40-taper vertical and horizontal mills
  • 15k Speed
  • 40 Taper
  • 30 hp Power
  • Inline Drive
  • Option Info
  • Torque CHart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 15,000-rpm spindle provides high rpm without sacrificing low-speed torque or high-speed power. The inline spindle is quiet and very powerful ,while providing 85% faster speed than the standard 8100-rpm version. That directly translates to 85% shorter cycle times when machining at full speed.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • Inline direct-drive spindle
  • 85% faster spindle speed and feedrates than the 8100-rpm spindle
  • Increased performance for 3D profiling
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
