30k Spindle (30K-20T)
Product Image
GET QUOTE
30,000-rpm Spindle
    CNY ONLY
Standard Spindle for Compact Mills
  • 30k Speed
  • 20 Taper
  • 5 hp Power
  • Belt Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This Haas-built 30,000-rpm spindle is designed for use with small-diameter tools, such as those found in the medical, dental, and jewelry industries. The spindle is prized by those industries, because it produces excellent surface finishes when using small-diameter cutters in 3D applications.
  • Increases production by increasing material removal rates due to the high rpm range
  • Improves surface finish by maintaining a constant high surface speed, especially when 3D profiling
  • Optimizes tool life by using proper surface speeds, particularly on small tools, preventing premature tool wear
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
