30k Integral Spindle (30K-30T-INTG)
Product Image
GET QUOTE
30,000-rpm Integral Motor Spindle, BT30
    CNY ONLY
High-speed 30-taper spindle for VF Series and Mold Machines
  • 30k Speed
  • BT30 Taper
  • 14 hp Power
  • Integral Motor Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This BT30 taper 14 hp (19 kW) spindle features an integral-motor design for long, trouble-free life. This option also requires a side-mount tool changer. Note: Use only specified BT30 tooling with drive slots. Do not operate the spindle at any time without a toolholder in the spindle taper.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
This option requires a side-mount tool changer. Rigid tapping is not available. Not compatible with through-spindle coolant systems or TSC Ready.
  • 3.5 times faster spindle speed than the 8100-rpm inline spindle
  • Integral-motor design
  • Ideal for small-diameter tools
  • Best performance for 3D profiling
  • Rigid Tapping is not available with this option
  • Through-Spindle-Coolant is not available with this option
  • Use only BT tooling with drive slots
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
