4.5k Spindle (4.5K-30HP-A2-6)
Product Image
GET QUOTE
4500-rpm Spindle
    CNY ONLY
High-speed spindle for ST-25 and ST-30 series lathes
  • 4.5k speed
  • A2-6 Nose
  • 30 hp power
  • Belt drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 4500-rpm spindle provides 32% more speed than the standard spindle, making it the best choice for turning small-diameter parts, or when part output is a priority.
  • Improves part finishes
  • Increases part output
  • Rigid and thermally stable
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
