8k Spindle, 10 hp (8K-40T-10HP)
Product Image
GET QUOTE
8000-rpm Spindle, 10 hp (7.5 kW)
    CNY ONLY
Standard spindle for the Mini Mill
  • 8k Speed
  • 40 Taper
  • 10 hp Power
  • Belt Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
The belt-driven spindle yields speeds to 8000 rpm for cutting aluminum, yet provides plenty of low-end torque for cutting steel.
  • Excellent medium-duty spindle
  • Grease-packed bearings for long life
  • Increased performance for 3D profiling
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
