G-code, M-code, and Setting
Service Home G184 Reverse Tapping Canned Cycle For Left Hand Threads (Gr...
G184 Reverse Tapping Canned Cycle For Left Hand Threads (Group 09)
F - Feed Rate in inches (mm) per minute
R - Position of the R plane
S - RPM, called prior to G184 is necessary
* W - Z-axis incremental distance
* X - X-axis motion command
* Q - Peck Depth (always incremental)
Z - Position of bottom of hole
* indicates optional
Programming Notes: When tapping, the feedrate is the lead of the thread. See example of G84, when programmed in G99 Feed per Revolution.
It is not necessary to start the spindle CCW before this canned cycle; the control does this automatically.
G184 Reverse Tapping Canned Cycle: [1] Rapid, [2] Feed, [3] Start or end of stroke, [4] Left-hand tap, [5] Starting plane, [R] R plane, [Z] Position of the bottom of the hole.
