G-code, M-code, and Setting
Service Home G10 Set Offsets (Group 00)
G10 lets you set offsets within the program. G10 replaces manual offset entry (i.e. Tool length and diameter, and work coordinate offsets).L -- Selects offset category.
L2 Work coordinate origin for G52 and G54-G59
L10 Length offset amount (for H code)
L1 orL11Tool wear offset amount (for H code)
L12 Diameter offset amount (for D code)
L13 Diameter wear offset amount (for D code)
L14 Sets max tool speed (for P code and R code)
L20 Auxiliary work coordinate origin for G110-G129
P -- Selects a specific offset.
P1-P200 Used to reference D or H code offsets (L10-L13) or Specifies Tool Number (L14)
P0G52 references work coordinate (L2)
P1-P6G54-G59 references work coordinates (L2)
P1-P20G110-G129 references auxiliary coordinates (L20)
P1-P99G154 reference auxiliary coordinate (L20)
*R Offset value or increment for length and diameter.
*X X-Axis zero location.
*Y Y-Axis zero location.
*Z Z-Axis zero location.
*A A-Axis zero location.
*B B-Axis zero location.
*C C-Axis zero location.
*indicates optional
O60100 (G10 SET OFFSETS) ;
G10 L2 P1 G91 X6.0 ;
(Move coordinate G54 6.0 to the right) ;
G10 L20 P2 G90 X10. Y8. ;
(Set work coordinate G111 to X10.0 Y8.0) ;
G10 L10 G90 P5 R2.5 ;
(Set offset for Tool #5 to 2.5) ;
G10 L12 G90 P5 R.375 ;
(Set diameter for Tool #5 to .375") ;
G10 L14 P5 R500 ;
(Set max RPM for Tool #5 to 500) ;
G10 L20 P50 G90 X10. Y20. ;
(Set work coordinate G154 P50 to X10. Y20.) ;
