G-code, M-code, and Setting
Service Home G174 CCW / G184 CW Non-Vertical Rigid Tap (Group 00)
F - Feedrate
X - X position at bottom of hole
Y - Y position at bottom of hole
Z - Z position at bottom of hole
* S - Spindle Speed
* indicates optional
A specific X, Y, Z, A, B position must be programmed before the canned cycle is commanded. This position is used as the Start position.
This G code is used to perform rigid tapping for non-vertical holes. It may be used with a right-angle head to perform rigid tapping in the X or Y Axis on a three-axis mill, or to perform rigid tapping along an arbitrary angle with a five-axis mill. The ratio between the feedrate and spindle speed must be precisely the thread pitch being cut.
It is not necessary to start the spindle before this canned cycle;
the control does this automatically.
