G-code, M-code, and Setting
Service Home G89 Bore In, Dwell, Bore Out Canned Cycle (Group 09)
F - Feedrate
L - Number of holes if G91 (Incremental Mode) is used
P - The dwell time at the bottom of the hole
* R - Position of the R plane (position above the part)
X - X-Axis location of holes
Y - Y-Axis location of holes
Z - Position of the Z Axis at the bottom of hole
* indicates optional
NOTE
The P values are modal. This means if you are in the middle of a canned cycle and a G04 Pnn or an M97 Pnn is used the P value will be used for the dwell / subprogram as well as the canned cycle.
CAUTION
Unless you specify otherwise, this canned cycle uses the most recently commanded spindle direction ( M03 , M04 , or M05 ). If the program did not specify a spindle direction before it commands this canned cycle, the default is M03 (clockwise). If you command M05 , the canned cycle will run as a  no-spin cycle. This lets you run applications with self-driven tools, but it can also cause a crash. Be sure of the spindle direction command when you use this canned cycle.
G89 Bore and Dwell and Canned Cycle
