G-code, M-code, and Setting
Service Home M21 / M22 Tailstock Advance/Retract (Optional)
M21 and M22 position the tailstock. M21 uses Settings 341and 342 to move to the Tailstock Advance DistanceM22 uses Setting 105 to move the tailstock to the Retract Point.
NOTE: ST10 does not use any settings (105, 341, 342).
Adjust pressure using the valves on the HPU (except ST-40, which uses Setting 241 to define hold pressure). For information on proper ST tailstock pressure, refer to Hydraulic Tailstock (ST-20/30) and ST-40 Servo Tailstock Operation .
CAUTION: Do not use an M21 in the program if the tailstock is positioned manually. If this is done, the tailstock backs away from the workpiece and then repositions against the workpiece, which may cause the workpiece to drop.
Set Screw Hold Pressure Valve: [1] Locking knob, [2] Adjustment knob.
