G-code, M-code, and Setting
Service Home 32 - Coolant Override
This setting controls how the coolant pump operates. When Setting 32 NORMAL, you can press [COOLANT] , or you can use M-codes in a program, to turn the coolant pump on and off.
When Setting 32 is OFF, the control gives the message FUNCTION LOCKED when you press [COOLANT] . The control gives an alarm when a program commands the coolant pump on or off.
When Setting 32 is IGNORE, the control ignores all programmed coolant commands, but you can press [COOLANT] to turn the coolant pump on or off.
NOTE
Starting in software version 100.22.000.1000 and higher the control will monitor the coolant level.
NOTE
When Setting 32 is set to NORMAL and IGNORE the control will allow Coolant Level Monitoring to take place.
NOTE
When Setting 32 is set to OFF it will disable the monitor and all the notifications of Low Coolant condition. Only the coolant gauge will be shown indicating the remaining level.
