G-code, M-code, and Setting
Service Home 33 - Coordinate System
This setting changes the way the Haas control recognizes the work offset system when a G52 or G92 is programmed. It can be set to FANUC or HAAS.Set to FANUC with G52:Any values in the G52 register are added to all work offsets (global coordinate shift). This G52 value can be entered either manually or through a program. When FANUC is selected, pressing [RESET] , commanding an M30, or machine power down clears out the value in G52.Set to HAAS with G52:Any values in the G52 register are added to all work offsets. This G52 value can be entered either manually or through a program. The G52 coordinate shift value is set to zero (zeroed) by manually entering zero, or by programming it with G52 X0, Y0, and/or Z0.
