G-code, M-code, and Setting
Service Home 81 - Tool At Power Up
When [POWER UP] is pressed, the control changes to the tool specified in this setting. If zero (0) is specified, no tool change occurs at power up. The default setting is 1.
Setting 81, causes one of these actions to occur after you press [POWER UP] :
  • If Setting 81 is set to zero, the carousel rotates to pocket #1. No tool change is performed.
  • If Setting 81 contains the tool #1, and the tool currently in the spindle is tool #1, and [ZERO RETURN] then [ALL] are pressed, the carousel remains at the same pocket and no tool change is performed.
  • If Setting 81 contains the tool number of a tool not currently in the spindle, the carousel rotates to pocket #1 and then to the pocket containing the tool specified by Setting 81. A tool change is performed to change the specified tool into the spindle.
