6 - HFL Series - Maintenance
HFL - Series Operator's/Service Manual
  • 1 - HFL Series - Introduction
  • 2 - HFL - Safety
  • 3 - HFL - Pre-Installation
  • 4 - HFL - Installation
  • 5 - HFL Series - Operation
  • 6 - HFL Series - Maintenance
  • 7 - HFL Series - Troubleshooting
  • 6.1 HFL MAINTENANCE SCHEDULE
  • 6.2 HFL-3015 SERIES - SERVICE PARTS LIST
  • 6.3 HFL-1313 SERIES - SERVICE PARTS LIST
**Under Construction**
6.2 HFL-3015 Series - Service Parts List
Revision B - 03/2026
Machines Part Number DESCRIPTION
HFL-3015-3 93-5781 LASER CUTTING HEAD 3KW HFL-3015-3
93-5782 LASER SOURCE 3KW HFL-3015-3
93-5783 TRANSFORMER 50KVA 3 PHASE HFL-3015-3
93-5795 DUST COLLECTOR HFL-3015-3
93-5808 WATER CHILLER HFL-3015-3
93-5809 VOLTAGE REGULATOR HFL-3015-3
93-5830 DUST COLLECTOR FILTER COVER HFL-3015
93-5831 DUST COLLECTOR GASKET HFL-3015
93-5832 DUST COLLECTOR CONTROL BOARD HFL-3015
93-5833 DUST COLLECTOR HMI HFL-3015
93-5893 NOZZLE ASSEMBLY HFL-3015-3
93-5894 PROTECTIVE LENS ASSY HFL-3015-3
59-5987 AC CONTACTER DUST COLLECTOR 3KW HFL
93-5988 CIRCUIT BREAKER DUST COLLECTOR 3KW HFL
HFL-3015-3/6 93-5784 LIGHTS HFL-3015-3/6
93-5785 CAMERA HFL-3015-3/6
93-5786 REMOTE CONTROL HFL-3015-3/6
93-5787 STATUS LIGHT HFL-3015-3/6
93-5788 DISPLAY SCREEN HFL-3015-3/6
93-5789 COMPUTER HFL-3015-3/6
93-5790 LUBE PUMP HFL-3015-3/6
93-5791 PROX SENSOR HFL-3015-3/6
93-5792 MAGNET SWITCH HFL-3015-3/6
93-5793 SERVO DRIVER Z-AXIS, HFL-3015-3/6
93-5811 SERVO DRIVER X-AXIS HFL-3015-3/6
93-5812 SERVO DRIVER Y-AXIS HFL-3015-3/6
93-5813 SERVO MOTOR Z-AXIS HFL-3015-3/6
93-5814 SERVO MOTOR X-AXIS HFL-3015-3/6
93-5815 SERVO MOTOR Y-AXIS HFL-3015-3/6
25-17652 TABLE SLATS HFL-3015-3/6
93-5829 DUST COLLECTOR DIAPHRAGM VALVE HFL-3015
93-5840 TTW CABLE HFL-3015-3/6
93-5841 DUST COVER BACK LEFT HFL-3015-3/6
93-5842 DUST COVER FRONT LEFT HFL-3015-3/6
93-5843 DUST COVER FRONT RIGHT HFL-3015-3/6
93-5844 DUST COVER BACK RIGHT HFL-3015-3/6
93-5845 DUST COVER BEAM HFL-3015-3/6
93-5947 PALLET TRUCKS W/WHEELS HFL 3015-3/6
93-5948 DISPLAY SCREEN MOUNTING TABS HFL-3015-3
93-5857 SERVO MOTOR XFMR 10KVA, 3PH HFL-3015-3/6
93-5897 SOLENOID VALVE LUBE CABINET HFL-3015-3/6
93-5898 AIR REGULATOR LUBE CABINET HFL-3015-3/6
93-5899 AIR FILTER ACCESS PANL HFL-3015-3/6
93-5900 DIGITAL PRESS SWITCH O2 HFL-3015-3/6
93-5901 DIGITAL PRESS SWITCH N2/AIR HFL-3015-3/6
93-5930 E-STOP BUTTON HFL-3015-3/6
93-5929 COPPER TRACK BRUSH HFL-3015-3/6
93-5928 COPPER BRUSH FOR PALLET HFL-3015-3/6
93-5927 BREAKER 3P, 60A HFL-3015-3/6
93-5926 BREAKER 3P, 63A HFL-3015-3/6
93-5925 BREAKER 3P, 25A HFL-3015-3/6
93-5924 BREAKER 3P, 10A HFL-3015-3/6
93-5923 BREAKER 1P, 6A HFL-3015-3/6
93-5922 CONTACTOR 3P, 32A HFL-3015-3/6
93-5921 POWER SUPPLY 480, 20A HFL-3015-3/6
93-5920 BREAKER 2P, 10A HFL-3015-3/6
93-5919 MANUAL MTR STARTER 24A-32A HFL-3015-3/6
93-5918 MANUAL MTR STARTER 9A-14A HFL-3015-3/6
93-5917 MANUAL MTR STARTER 6A-10A HFL-3015-3/6
93-5916 MANUAL MTR STARTER 4A-6.A HFL-3015-3/6
93-5915 SAFETY RELAY 3NO/1NC HFL-3015-3/6
93-5914 FSCUT TERMINAL BOARD HFL-3015-3/6
93-5913 FSCUT EXTENSION BOARD HFL-3015-3/6
93-5912 IO EXTENSION MODULE HFL-3015-3/6
93-5986 THERMAL OVERLOAD RELAY DUST COLLCTOR HFL
93-5989 SELECTOR SWITCH DUST COLLECTOR HFL
93-5990 SELECTOR SWITCH DUST COLLECTOR HFL
93-5991 GREEN PUSH BUTTON DUST COLLECTOR HFL
93-5992 RED PUSH BUTTON DUST COLLECTOR HFL
93-5993 AUTOTRANSFORMER DUST COLLECTOR HFL
93-5994 DELTA LOCK DUST COLLECTOR HFL
HFL-3015-6 93-5796 LASER CUTTING HEAD 6W HFL-3015-6
93-5797 LASER SOURCE 6W HFL-3015-6
93-5798 TRANSFORMER 80KVA 3PHASE HFL-3015-6
93-5799 DUST COLLECTOR HFL-3015-6
93-5806 WATER CHILLER HFL-3015-6
93-5807 VOLTAGE REGULATOR HFL-3015-6
93-5877 NOZZLE ASSY HFL-3015-6
93-5879 PROTECTIVE LENS ASSY HFL-3015-6
93-5995 AC CONTACTOR DUST COLLECTOR 6KW HFL
93-5996 CIRCUIT BREAKER DUST COLLECTOR 6KW HFL
6.3 HFL-1313 Series - Service Parts List
Revision A - 03/2026
Service Parts List
Machine PART NUMBER DESCRIPTION
HFL-1313 93-5977 TTW CABLE SPC-140 HFL-1313
93-5997 Y-AXIS DUST COVER HFL-1313
93-5998 X-AXIS DUST COVER HFL-1313
93-5978
INTERIOR LIGHT HFL-1313
93-5979 DISPLAY SCREEN HFL-1313
93-5980 PROXIMITY SENSOR HFL-1313
93-5981 SERVO DRIVER Y-AXIS HFL-1313
93-5982 SERVO MOTOR Y-AXIS HFL-1313
93-5983 CIRCUIT BREAKER HFL-1313
93-5984 SAFETY RELAY HFL-1313
93-5985 AIR FILTER HFL-1313
93-5999 PARTS CATCHER CART HFL-1313
