4 - HFL - Installation
HFL - Series Operator's/Service Manual
  • 1 - HFL Series - Introduction
  • 2 - HFL - Safety
  • 3 - HFL - Pre-Installation
  • 4 - HFL - Installation
  • 5 - HFL Series - Operation
  • 6 - HFL Series - Maintenance
  • 7 - HFL Series - Troubleshooting
  • 4.1 HFL-3015 Installation
  • 4.2 HFL-1313 Installation
**Under Construction**
HFL-3015 - Installation
AD0982
Installation Requirements
This procedure will guide you through the installation of a HFL-3015 Fiber Laser. This fiber laser cutting machine is is equipped with the following:
  • Laser Source System
  • Pallet Changer
  • Dust Extractor
  • Desktop Windows 11 Operating System
  • Safety Light Curtains
Pre-Installation
This system should be installed in an environment that meets the following requirements:
  • Smoke and dust-free
  • Flat foundation
  • Nitrogen Gas
  • Oxygen Gas
  • Air
  • Forklift (15,000 lbs capacity + 7ft minimum fork extensions + 12ft minimum fork lifting height)
  • 2 Pallet Jacks
  • 11 Gallons of Deionized Water
  • Vactra No. 2 Oil (93-5656)
  • Floor Space
Unpacking HFL-3015
Machine will arrive with three pallets. First pallet will be the machine. The machine will have the pallet changer bed among other accessories required to install the machine. See the checklist provided to ensure that all parts have been received.
With the use of a forklift and lifting chain sling, remove the pallet changer bed from the inside of the machine using the 4 eyebolts that should be placed in all 4 corners of the pallet changer bed.
The second pallet includes the following components:
  1. Voltage Regulator
  2. Main Transformer
  3. Servo Transformer
  4. PC
  5. Laser Head + Laser Source
The third pallet includes the Dust Collector.
Machine Layout
This is a visual representation for the layout for the HFL-3015 3/6kW machines. Refer to layout drawing found in this link for dimesnions needed for the floor space.
Air Connections
Electrical Installation 3kW
Electrical Installation 6kW
HFL-3015 Shipping Bracket Removal
Z-axis Laser Cutting Head Shipping Brackets
X-axis Shipping Brackets
HFL-3015 Pallet Changer Installation
HFL-3015 Leveling
HFL-3015 Maintenance Schedule
This procedure will guide you through the installation of a HFL-1313 Fiber Laser. This fiber laser cutting machine is is equipped with he following:
  • Dust Extractor
