10 - TL - Maintenance
Toolroom Lathe - Operator's Manual Supplement
  • 1 - TL - Introduction
  • 2 - TL - Legal Information
  • 3 - TL - Safety
  • 4 - TL - Installation
  • 5 - TL - Control Icons
  • 6 - TL - Operation
  • 7 - TL - G-Codes
  • 8 - TL - M-Codes
  • 9 - TL - Settings
  • 10 - TL - Maintenance
  • 10.1 Maintenance
10.1 Maintenance
Toolroom Lathe Lubrication
Regular maintenance is important to make sure that your machine has a long and productive life with minimal downtime. The most common maintenance tasks are simple and you can do them yourself. You can also ask your HFO about their comprehensive preventive maintenance program for complex maintenance tasks.
Toolroom Lathe Lubrication:
The linear guides, ball screws, optional tailstock, and optional steady rest are manually lubricated. Grease fittings provide lubrication to the Z-Axis saddle, four trucks, and ball screw, as well as, the X-Axis cross-slide, four trucks, and ball screw.
Manually lubricate the optional tailstock. Three grease fittings on the quill and two rails provide lubrication points. Manually lubricate the rail mounting-points on the optional steady rest.
Cycle the X-Axis and Z-Axis daily and lubricate them weekly to ensure proper lubrication. Manually lubricate the chuck or work holding every eight hours of operation to ensure proper lubrication.
The current Maintenance Schedule and recommended type of lubricant is found in the Haas website.
