8m PCB Reset Behavior
As of software version 100.19.000.1400 the M-code relay reset behavior has changed.
When an alarm occurs or [RESET] or [EMERGENCY STOP] is pressed, some relays will turn off, while others will stay on.
Use the following table to determine if a specific relay will turn off:
Command Used to Turn on Relay M-Code Relay Bank Will turn off with [RESET], [E-STOP], or Alarm
M51-M55
I/O PCB M21 - M25 User Relays
YES
M59 P112 - P116 I/O PCB M21 - M25 User Relays YES
M59 P90 - P97
8M PCB Bank 1 (JP1)
YES¹
M59 P103 - P110
8M PCB Bank 2 (JP2) without APL installed
YES
M59 P103 - P110
8M PCB Bank 2 (JP2) with APL installed
NO²
M59 P79 - P86
8M PCB Bank 3 (JP3)
NO
NOTES:
  1. Behavior of bank 1 (JP1) changes when the “Status Relays” feature is enabled. (Factory Setting 315.26).  For more information on this feature refer to MDC - 8M Option Status Relays.
  2. Some factory options, such as Autodoor and APL, use relays from bank 2 and bank 4 when enabled. If these options are installed on your machine, the used relays may or may not turn off upon reset.
