Mill - Operators Manual - Safety
Safety Notes
CAUTION: Only authorized and trained personnel may operate this equipment. You must always act in accordance with the Operator's manual, safety decals, safety procedures, and instructions for safe machine operation. Untrained personnel present a hazard to themselves and the machine
IMPORTANT: Do not operate this machine until you have read all warnings, cautions, and instructions
CAUTION: The sample programs in this manual have been tested for accuracy, but they are for illustrative purposes only. The programs do not define tools, offsets, or materials. They do not describe workholding or other fixturing. If you choose to run a sample program on your machine, do so in Graphics mode. Always follow safe machining practices when you run an unfamiliar program.
All CNC machines present hazards from rotating cutting tools, belts and pulleys, high voltage electricity, noise, and compressed air. When you use CNC machines and their components, you must always follow basic safety precautions to reduce the risk of personal injury and mechanical damage.
The work area must be adequately illuminated to allow clear view and safe operation of the machine. This includes the operator work area and all areas of the machine that might be accessed during maintenance or cleaning.Adequate illumination is the responsibility of the user.
Cutting tools, workholding, workpiece and coolant are beyond the scope and control of Haas Automation, Inc. Each of these potential hazards associated with it (sharp edges, heavy lifting considerations, chemical composition, etc) and it is the responsibility of the user to take appropriate action (PPE, training, etc).
Cleaning of the machine is required during normal use and prior to maintenance or repair. Optional equipment is available to aid cleaning such as washdown hoses, chip conveyors and chip augers. Safe use of this equipment requires training and might require appropriate PPE and is the responsibility of the user.
This operator’s manual is intended as a reference guide and is not to be the sole source of training. Complete operator training is available from the authorized Haas distributor.
Summary of Types of Operation for Haas Automation Machine Tools
Haas CNC Mills are intended for cutting and shaping of metals and other hard materials. They are general purpose in nature and a list of all of those materials and types of cutting would never be complete. Almost all cutting and shaping is performed by a rotating tool mounted in a spindle. Rotation of the mill is not required. Some cutting operations require liquid coolant. That coolant is also an option depending on the type of cutting.
Operations of Haas Mills are separated into three areas. They are: Operations, Maintenance, and Service. Operations and Maintenance are intended to be performed by a trained and qualified machine operator. This Operator's Manual contains some of the information necessary to operate the machine. All other machine operations are to be considered Service. Service is only to be performed by specially trained service personnel.
Operation of this machine consists of the following:
  1. Machine Setup
    • Machine setup is done to initially set up the tools, offsets, and fixtures required to perform a repetitive function that later is called machine operation. Some machine setup functions can be done with the door open but are limited to “hold to run”.
  2. Machine operating in Automatic Mode
    • Automatic operation is initiated with Cycle-Start and can only be done with the doors closed.
  3. Operator loading and unloading of materials (parts)
    • Parts loading and unloading is what precedes and follows an automatic operation. This must be done with the doors open and all machine automatic motion is stopped when the door is open.
  4. Operator loading and unloading of cutting tools
    • Tool loading and unloading is done less often than setup. It is often required when a tool has become worn and must be replaced.
Maintenance only consists of the following:
  1. Adding and maintaining condition of coolant
    • Adding coolant and maintaining coolant concentration is required at regular intervals. This is a normal operator function and is either done from a safe location outside of the work enclosure or with the doors open and the machine stopped.
  2. Adding lubricants
    • Adding lubricants for spindle and axes is required at regular intervals. These are often months or years in length. This is a normal operator function and is always done from a safe location outside of the work enclosure.
  3. Cleaning chips out of the machine
    • Cleaning out of chips is required at intervals dictated by the type of machining performed. This is a normal operator function. It is performed with the doors open and all of the machine operation is stopped.
Service only consists of the following:
  1. Repairing of a machine that is not operating correctly
    • Any machine that is not operating correctly requires service by factory trained personnel. This is never an operator function. It is not considered maintenance. Installation and service instructions are provided separately from the Operator’s Manual.
  2. Machine moving, unpacking, and installation
    • Haas machines are shipped to a user’s location almost ready to operate. They still require a trained service person to complete the installation. Installation and service instructions are provided separately from the Operator’s Manual.
  3. Machine packing
    • Machine packing for shipment requires the same packing material supplied by Haas in the original shipment. Packing requires a trained service person to complete the installation. Shipping instructions are provided separately from the Operator’s Manual.
  4. Decommission, dismantle and disposal
    • Machine is not expected to be disassembled for shipment; it can be moved in its entirety in the same manner in which it was installed. Machine can be returned to the manufacturer’s distributor for disposal; manufacturer accepts any/all components for recycling per Directive 2002/96/EC.
  5. End-of-life disposal
    • End-of-life disposal must conform to the laws and regulations in the region the machine is located. This is a jointly the responsibility of the owner and seller of the machine. The risk analysis does not address this phase.
Read Before Operating
DANGER: Do not enter the machining area any time the machine is in motion, or at any time that machine motion is possible. Severe injury or death may result. Motion is possible when the power is on and the machine is not in [EMERGENCY STOP].
Basic safety:
  • This machine can cause severe bodily injury.
  • This machine is automatically controlled and may start at any time.
  • Consult your local safety codes and regulations before you operate the machine. Contact your dealer if you have questions about safety issues.
  • It is the machine owner’s responsibility to make sure that everyone who is involved in installing and operating the machine is fully acquainted with the operation and safety instructions provided with the machine, BEFORE they work with the machine. The ultimate responsibility for safety rests with the machine owner and the individuals who work with the machine.
  • Use appropriate eye and ear protection when you operate the machine.
  • Use appropriate gloves to remove processed material and to clean the machine.
  • Replace windows immediately if they are damaged or severely scratched.
  • Keep the side windows locked during operation (if available).
Electrical safety:
  • The electrical power must meet the required specifications. Attempting to run the machine from any other source can cause severe damage and will void the warranty.
  • The electrical panel should be closed and the key and latches on the control cabinet should be secured at all times, except during installation and service. At those times, only qualified electricians should have access to the panel. When the main circuit breaker is on, there is high voltage throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures; therefore, extreme caution is required. Once the machine is installed, the control cabinet must be locked, with the key available only to qualified service personnel.
  • Do not reset a circuit breaker until the reason for the fault is investigated and understood. Only Haas-trained service personnel should troubleshoot and repair Haas equipment.
  • Do not press [POWER UP] on the control pendant before the machine is fully installed.
Operation Safety:
DANGER: To avoid injury verify that the spindle has stopped turning before opening the doors. In the event of a loss of power the spindle will take much longer to coast to a stop.
  • Do not operate the machine unless the doors are closed and the door interlocks are functioning correctly.
  • Check for damaged parts and tools before you operate the machine. Any part or tool that is damaged should be properly repaired or replaced by authorized personnel. Do not operate the machine if any component does not appear to be functioning correctly.
  • Rotating cutting tools can cause severe injury. When a program runs, the mill table and spindle head can move rapidly at any time.
  • Improperly clamped parts machined at high speeds/feeds may be ejected and puncture the enclosure. It is not safe to machine oversized or marginally clamped parts.
CAUTION: Manual or Automatic closing of the enclosure doors is a potential pinch point. With Auto Door, the door may be programmed to close automatically, or by pressing the door open/close button on the operators pendant. Avoid putting hands or appendages in the door while closing either manually or automatically.
Release of person trapped in the machine:
  • No person should ever be located inside the machine during operation.
  • In the unlikely event that a person is trapped inside the machine the emergency stop button should be immediately be depressed and the person removed.
  • If the person is pinched or entangled the machine should be powered off; then the machine axes can be moved by use of a large external force in the direction required to free the person.
Recover from a jam or blockage:
  • Of the chip conveyor - Follow the cleaning instructions on the Haas service site (go to www.haascnc.com click on the Service tab). If necessary, close the doors and reverse the conveyor so the jammed part or material is accessible, and remove. Use lifting equipment or get assistance for lifting heavy and awkward parts.
  • Of a tool and material/part - Close the doors, press [RESET] to clear and displayed alarms. Jog the axis so the tool and material are clear.
  • Of the Automatic Tool Changer/tool and spindle - Press [RECOVER] and follow the on-screen instructions.
  • If the alarms do not reset or you are unable to clear a blockage, contact your Haas Factory Outlet (HFO) for assistance.
Follow these guidelines when you work with the machine:
  • Normal operation - Keep the door closed and guards in place (for non-enclosed machines) while the machine operates.
  • Part loading and unloading – An operator opens the door, completes the task, closes the door, and then presses [CYCLE START] (starting automatic motion).
  • Machining job set-up – When set-up is complete, turn the set-up key to lock out set-mode and remove the key.
  • Maintenance / Machine Cleaner– Press [EMERGENCY STOP] or [POWER OFF] on the machine before you enter the enclosure.
Periodic inspection of machine safety features:
  • Press any of the Emergency Stop buttons to verify all motion is stopped and a 107 EMERGENCY STOP Alarm is displayed.
  • A monthly inspection of each Emergency Stop button should be performed.
  • Inspect door interlock mechanism for proper fit and function.
  • Inspect safety windows and enclosure for damage or leaks.
  • Verify all enclosure panels are in place.
Door Safety Interlock inspection:
  • Inspect the door interlock, verify the door interlock key is not bent, misaligned, and that all fasteners are installed.
  • Inspect the door interlock itself for any signs of obstruction or misalignment.
  • Immediately replace an components of the Door Safety Interlock system that do not meet this criteria.
Door Safety Interlock verification:
  • With the machine in run mode, close the machine door, run the spindle at 100 RPM, pull the door and verify the door does not open.
Machine Enclosure and Safety Glass inspection and testing:
Routine Inspection:
  • Visually inspect the enclosure and safety glass for any signs of distortion, breakage or other damage.
  • Replace the Lexan windows after 7 years or if they are damaged or severely scratched.
  • Keep all safety glass and machine windows clean to allow proper viewing of the machine during operations.
  • A daily visual inspection of the machine enclosure to verify all panels are in place should be performed.
Testing of machine enclosure:
  • No testing of the machine enclosure is necessary.
Machine Evrionmental Limits
This table list the environmental limits for safe operation:
Environmental Limits (Indoor Use Only)
  Minimum Maximum
Operating Temperature 41 °F (5.0 °C) 122 °F (50.0 °C)
Storage Temperature -4 °F (-20.0 °C) 158 °F (70.0 °C)
Ambient Humidity 20% relative, non-condensing 90% relative, non-condensing
Altitude Sea Level 6,000 ft. (1,829 m)
CAUTION: Do not operate the machine in explosive atmospheres (explosive vapors and/ or particulate matter).
Machine with Haas Robot Package
Machine and robot environment is intended to be a machine shop or industrial installation. Shop lighting is the users responsibility.
Machine Noise Limits
CAUTION: Take precautions to prevent hearing damage from machine/machining noise. Wear ear protection, change your application (tooling, spindle speed, axis speed, fixturing, programmed path) to reduce noise, or restrict access to machine area during cutting.
Typical noise levels at the operator’s position during normal operation are as follows:
  • A-Weighted sound pressure level measurements will be 69.4dB or lower.
  • C-Weighted instantaneous sound pressure levels will be 78.0dB or lower.
  • LwA (sound power level A-weighted) will be 75.0dB or lower.
NOTE: Actual noise levels while cutting material are greatly affected by the user’s choice of material, cutting tools, speeds and feeds, workholding and other factors. These factors are application specific and are controlled by the user, not Haas Automation Inc
Unattended Operation
Fully enclosed Haas CNC machines are designed to operate unattended; however, your machining process may not be safe to operate unmonitored.
As it is the shop owner’s responsibility to set up the machine safely and use best practice machining techniques, it is also the owner’s responsibility to manage the progress of these methods. You must monitor your machining process to prevent damage, injury, or loss of life if a hazardous condition occurs.
For example, if there is the risk of fire due to the material machined, then you must install an appropriate fire suppression system to reduce the risk of harm to personnel, equipment, and the building. Contact a specialist to install monitoring tools before machines are allowed to run unattended.
It is especially important to select monitoring equipment that can immediately detect a problem and perform an appropriate action without human intervention.
Run/Setup Mode Restrictions
All Haas CNC machines are equipped with locks on the operator doors and a key switch on the side of the control pendant to lock and unlock setup mode. Generally, setup mode status (locked or unlocked) affects how the machine operates when the doors are opened.
Setup mode should be locked out (the keyswitch in the vertical, locked position) at most times. In Run and in Setup mode, the enclosure doors are locked closed during CNC program execution, spindle rotation or axis movement. The doors automatically unlock when the machine is not in cycle. Many machine functions are unavailable with the door open.
When unlocked, setup mode allows a skilled machinist more access to the machine to set up jobs. In this mode, machine behavior is dependent on whether the doors are opened or closed. The following charts summarize the modes and allowed functions.
Note: All these conditions follow assuming that the door is open and stays open before, during and the actions occur.
Danger: Do not attempt to override safety features. Doing so makes the machine unsafe and voids the warranty.
Machine Function RUN Mode SETUP Mode
Air Blast (AAG) On Not allowed. Not allowed.
Axis Jog using the Pendant Handle Jog Not allowed. Allowed.
Axis Jog using the RJH Handle Jog Not allowed. Allowed.
Axis Jog using the RJH shuttle knob Not allowed. Not allowed.
Axis Rapid using Home G28 or Second Home Not allowed. Not allowed.
Axis Zero Return Not allowed. Not allowed.
Automatic Pallet Change Not allowed. Not allowed.
APC Operation Buttons Not allowed. Not allowed.
Chip Conveyor CHIP FWD, REV Not allowed. Not allowed.
COOLANT button on pendant Not allowed. Allowed.
COOLANT button on RJH. Not allowed. Allowed.
Move Programmable Coolant Spigot Not allowed. Allowed.
Orient Spindle Not allowed. Not allowed.
Run a program, CYCLE START button on the pendant Not allowed. Not allowed.
Run a program CYCLE START button on the RJH Not allowed. Not allowed.
Run a program (Pallet) Not allowed. Not allowed.
Spindle FWD / REV button on the pendant Not allowed. Not allowed.
Spindle FWD / REV on the RJH Not allowed. Not allowed.
Tool Change ATC FWD / ATC REV. Not allowed. Not allowed.
Tool Release from Spindle Allowed. Allowed.
Through Spindle Coolant (TSC) On Not allowed. Not allowed.
Tool Air Blast (TAB) On Not allowed. Not allowed.
Robot Cells
A machine in a robot cell is allowed to run a program while the door is open, regardless of the position of the Run-Setup key. While the door is open, the spindle speed is limited to the lower of the factory RPM limit or Setting 292, Door Open Spindle Speed Limit. If the door is opened while the spindle RPM is above the limit, the spindle will decelerate to the limit RPM. Closing the door removes the limit and the programmed RPM is restored.
This open-door condition is allowed only while a robot communicates with the CNC machine. Typically, an interface between the robot and the CNC machine addresses the safety of both machines.
Haas Robot Package
The Haas designed work cell made up of a CNC machine and a robot has been evaluated for CE compliance. Changes or variations to the Haas cell design should be re-evaluated for compliance to the applicable standards and are the responsibility of the user/integrator.
Robot is controlled by the CNC it is paired with. It does not respond to any external commands as it could cause hazardous conditions. Do not leave a network connection plugged into the robot controller. No remote control is permitted.
Run Mode
When in Run mode, unlocking the interlock and opening up the gate stops all motion, and no motion can be started until it is closed and locked.
Setup Mode
In Set up mode, speed limited motion such as jogging an axis of the robot can be performed in order to program a robot's path of motion, pick up position, set a robot's tool center point, (an offset), load and pick up parts from the spindle or part holder in the machine, etc. The robot program will also be able to be run slowly to prove out the programmed path of the robot.
NOTE: The max robot speed in setup mode is 7.9 in/sec (200mm/sec).
Robot Motion
Manual motion is only permitted in set up mode and is recommended only with limited speed of motion. High speed is permitted but 500mm clearance for the safety of the operator is required. This requires the set up and verification of DCS/keep out zone(s).
Level of task lighting required for the robot installation is to be provided by the end user. The robot does not require any lighting. But, light will be required for a user to load or unload parts or to perform maintenance, or service.
The Haas Robot Package installation procedure is located on the website. This procedure describes and verifies the functionality of the enabling device at install, i.e the buttons and how the remote jog handle is intended to be used. Scan the code below with your mobile device to go directly to the procedure.
Haas Robot Package 1 - VMC Installation
Haas Robot - FANUC Dual Check Safety (DCS)
Each Haas Robot is provided with FANUC's DCS System. This allows the user to define speed and positional limits to the robot. If the robot goes outside of these limits, DCS will stop the robot and remove power to the motors.
NOTE: Verify proper setup of the DCS zones at the time of robot installation and every 6 months. It should also be verified after a new job has been set up. Scan the code below with your mobile device to go directly to the procedure.
Haas Robot - FANUC Dual Check Safety - Setup
Operation
Recommendation of PPE including but not limited to gloves to protect from sharp edges and chips, eye glasses for eye protection, steel toed shoes etc. when handling parts or loading/unloading parts for the robot to handle.
WARNING: Loss of air pressure may cause the gripper to allow a part being held to slip or be dropped. Users should review grippers that they purchase and determine how they will respond to a loss of power or air pressure, so they know how to minimize any potential hazard.
The Haas Robot - Quick Start Guide is located on the website. This procedure helps the user set up a job with the Haas Robot. Scan the code below with your mobile device to go directly to the procedure.
Mist Extraction / Enclosure Evacuation
Some models have a provision installed that will allow for a mist extractor to be attached to the machine.
There is also an optional enclosure exhaust system available that helps keep the mist out of the machine enclosure.
It is entirely up to the owner/operator to determine if and what type of mist extractor is best suited for the application.
The owner/operator assumes all responsibility for the installation of the mist extraction system.
Spindle Safety Limit
Starting in software version 100.19.000.1100 a spindle safety limit has been added to the control.
This feature will display a warning message when the [FWD] or [REV] button is pressed and the previous commanded spindle speed is above the Spindle Maximum Manual Speed parameter. Press [ENTER] to go to the previous commanded spindle speed or press [CANCEL] to cancel the action.
Machine / Spindle Option Spindle Maximum Manual Speed
Mills 5000
NOTE:  These values can not be changed.
Modifications to the Machine
Haas Automation, Inc. is not responsible for damage caused by modifications you make to your Haas machine(s) with parts or kits not manufactured or sold by Haas Automation, Inc. The use of such parts or kits may void your warranty.
Some parts or kits manufactured or sold by Haas Automation, Inc. are considered user-installable. If you choose to install these parts or kits yourself, be sure to completely read the accompanying installation instructions.
Make sure you understand the procedure, and how to do it safely, before you begin. If you have any doubts about your ability to complete the procedure, contact your Haas Factory Outlet (HFO) for assistance.
Improper Coolants
Coolant is an important part of many machining operations. When it is correctly used and maintained, coolant can improve part finish, lengthen tool life, and protect machine components from rust and other damage. Improper coolants, however, can cause significant damage to your machine.
Such damage can void your warranty, but it can also introduce hazardous conditions to your shop. For example, coolant leaks through damaged seals could create a slipping hazard.
Improper coolant use includes, but is not limited to, these points:
  • Do not use plain water. This causes machine components to rust.
  • Do not use flammable coolants.
  • Do not use straight or “neat” mineral-oil products. These products cause damage to rubber seals and tubing throughout the machine. If you use a minimum-quantity lubrication system for near-dry machining, use only the recommended oils.
Machine coolant must be water-soluble, synthetic oil-based or synthetic-based coolant or lubricant.
NOTE: Be sure to maintain your coolant mixture to keep the coolant concentrate at acceptable levels. Improperly maintained coolant mixtures can allow machine components to rust. Rust damage is not covered by your warranty.
Ask your HFO or your coolant dealer if you have questions about the specific coolant that you plan to use.
Safety Decals
The Haas factory puts decals on your machine to quickly communicate possible hazards. If decals become damaged or worn, or if you need additional decals to emphasize a particular safety point, contact your Haas Factory Outlet (HFO).
NOTE: Never alter or remove any safety decal or symbol.
Be sure to familiarize yourself with the symbols on the safety decals. The symbols are designed to quickly tell you the type of information they give:
  • Yellow Triangle - Describes a hazard.
  • Red Circle with Slash-Through - Describes a prohibited action.
  • Green Circle - Describes a recommended action.
  • Black Circle - Gives information about machine or accessory operation.
Example Safety Decal Symbols: [1] Hazard Description, [2] Prohibited Action, [3] Recommended Action.
You may find other decals on your machine, depending on the model and options installed. Be sure to read and understand these decals.
Hazard Symbols - Yellow Triangles
Moving parts can entangle, trap, crush, and cut.
Keep all parts of your body away from machine parts when they move, or whenever motion is possible. Motion is possible when the power is on and the machine is not in [EMERGENCY STOP].
Secure loose clothing, hair, etc.
Remember that automatically controlled devices can start at any time.
Do not touch rotating tools.
Keep all parts of your body away from machines parts when they move, or whenever motion is possible. Motion is possible when the power is on and the machine is not in [EMERGENCY STOP].
Sharp tools and chips can easily cut skin.
The Regen is used by the spindle drive to dissipate excess power and will get hot.
Always use care around the Regen.
There are high voltage components on the machine that can cause electrical shock.
Always use care around high voltage components.
There are high voltage components on the machine that can cause arc flash, and electrical shock.
Take care to avoid opening electrical enclosures unless components are de-energized or proper personal protective equipment is worn. Arc flash ratings are on the nameplate.
Long tools are dangerous, especially at spindle speeds higher than 5000 RPM. The tools can break and eject from the machine.
Remember that machine enclosures are intended to stop coolant and chips. Enclosures may not stop broken tools or thrown parts.
Always check your setup and tooling before you start machining.
Machining operations can create hazardous chips, dust, or mist. This is a function of the materials being cut, the metalworking fluid and cutting tools used, and the machining speeds/feeds.
It is up to the owner/operator of the machine to determine if personal protective equipment such as safety goggles or a respirator is required and also if a mist extraction system is needed.
Some models have a provision for connecting a mist extraction system. Always read and understand the Safety Data Sheets (SDS) for the workpiece material, the cutting tools, and the metalworking fluid.
Prohibited Action Symbols - Red Circles with Slash-Through
Do not enter the machine enclosure when the machine is capable of automatic motion.
When you must enter the enclosure to complete tasks, press [EMERGENCY STOP] or power off the machine. Put a safety tag on the control pendant to alert other people that you are inside the machine, and that they must not turn on or operate the machine.
Do not machine ceramics.
Do not attempt to load tools with the spindle dogs misaligned with the cutouts in the toolholder V-Flange.
Do not machine flammable materials.
Flammable materials in particulate or vapor form can become explosive.
The machine enclosures is not designed to contain explosions or extinguish fire.
Do not use pure water as coolant. This will cause machine components to rust.
Always use a rust-inhibitive coolant concentrate with water.
Recommended Action Symbols - Green Circles
Keep the machine doors closed.
Always wear safety glasses or goggles when you are near a machine.
Airborne debris can cause eye damage.
Always wear hearing protection when you are near a machine.
Machine noise can exceed 70 dBA.
Make sure the spindle dogs are correctly aligned with the cutouts in the toolholder V-flange.
Note the location of the tool release button. Press this button only when you are holding the tool.
Some tools are very heavy. Handle these tools carefully; use both hands and have someone press the tool release button for you.
Informational Symbols – Black Circles
Maintain the recommended coolant concentration.
A "lean" coolant mixture (less concentrated than recommended) may not effectively prevent machine components from rusting.
A "rich" coolant mixture (more concentrated than recommended) wastes coolant concentrate without further benefit over the recommended concentration.
Other Safety Information
IMPORTANT: You may find other decals on your machine, depending on the model and options installed. Be sure to read and understand these decals.
