What are Settings
Service Home What are Settings
Recently Updated Last updated: 03/22/2019
What are Settings?
What are Settings
- Jump to Section - 1. Settings Explained Back to Top
Settings Explained
In general, settings store default values, activate functions, and change the way the machine behaves.
Changing Settings
Press [SETTINGS] to enter the setting pages. Press [PAGE UP] and [PAGE DOWN] to scroll through the setting pages. Use the cursor arrow keys to move to the desired setting, or type a setting number and press the [DOWN] cursor arrow key to go directly to that setting
Some settings use a limited set of values in a list. For example, a setting might give you options to set it either ON or OFF. You can scroll through the available options with the cursor arrow keys, and then press [ENTER] to set the value. Other settings take typed alphanumeric values. For example, a setting might specify the duration, in minutes, to keep a piece of equipment turned on. You would type the desired value and then press [ENTER] to set the value.
In some cases, you must press [EMERGENCY STOP] before you can change a setting. The message SERVO IS ON appears to remind you to press [EMERGENCY STOP].
