Backlash Compensation - NGC
Service Home How To Procedures Backlash Compensation - NGC
- Jump to Section - 1. Introduction 2. Backlash Compensation - NGC (2 steps) Back to Top
Recently Updated Last updated: 04/28/2025
Revision A - 4/2025
This procedure tells you how to set parameters to adjust for backlash. The backlash parameter values are the measured distance, entered in millimeters, the encoder must turn to adjust for lost mechanical motion in the axis.
If the backlash exceeds 0.0004" (0.01 mm) it must be corrected mechanically or the part finish and accuracy may be affected.
Prerequisites:
Do a bi-directional ballbar plot. Refer to Ballbar Analysis - Quick Check Mode.
Tools Required:
  • Haas Control Key
Find the backlash values [1] for the axis to adjust.
Perform these calculations:
  • Add the two values together.
    • Example:
      0.000093 + 0.000117 = 0.00021
  • Divided the result by 2 to find the average.
    • Example:
      0.00021 / 2 = 0.000105
  • Multiply the result by 25.4.
    • Example:
      0.000105 x 25.4 = 0.002667
On the Parameters screen, select the parameter for the axis you need to change.
Type the result of your calculation into the "Value" column [2].
 Note: The field in the "Value" column rounds the value entered to five decimal places.
Do the ballbar plot again to make sure your calculations are correct. Refer to Ballbar Analysis - Quick Check Mode.
