BMT Gearbox - Refill Procedure
Service Home How To Procedures BMT Gearbox - Refill Procedure
- Jump to Section - 1. Introduction (4 steps) 2. BMT45 Gearbox - Oil Refill (2 steps) 3. BMT65/75 Gearbox - Oil Refill (2 steps) Back to Top
Recently Updated Last updated: 07/30/2024
BMT Gearbox - Oil - Refill Procedure
AD0791
This service kit and document shows you how to refill a BMT Gearbox Housing.
  • 93-2365 SYNTHETIC GEAR/BEARING OIL 1QT/0.94L
  • 93-1933A MOBILITH SYNTHETIC GREASE 1QT/0.94L
Remove the fill plug [1].
Note : If the gearbox does not have this fill port proceed to remove one of the mufflers and use the muffler port as a fill point ensuring that only 1 quart of oil is used.
Fill the gearbox with 1 quart of 93-2365 until flows out of the fill plug [1].
Remove the TT-axis motor from the turret.
Fill the gearbox with 2 quarts of 93-1933A through theTT-axis motor mounting hole [1].
Important : If its not a live tooling BMT65/75 use 3 quarts.
