Broken Tool Detection (BTD) - Camera Replacement - AD0707
Service Home How To Procedures Broken Tool Detection (BTD) - Camera Replacement - AD0707
Recently Updated Last updated: 10/21/2023
Broken Tool Detection - Camera Replacement
AD0707
This procedure will show how to replace the camera of the Broken Tool Detection system that captures the before & after image of the tool.
This procedure should apply to the follow service kits:
  • 93-3822 SVC KIT BTD CAMERA ASSY
Replacement
Disconnect the camera cable 79-0159 [1] plugged into the USB adapter 74-2003 that connects into the USB port on the A62 processor.
Follow the camera cable from the control cabinet around the machine's enclosure panels.
Remove the camera cable.
Remove the top screw [1] on the broken tool detection brace.
Remove the middle screw [2] on the broken tool detection brace.
Remove the last screw [3] on the broken tool detection brace freeing the brace from the camera [4].
Remove the camera [4].
Install the camera [1] into the broken tool detection brace with screw [2].
Install the middle screw [3] into the broken tool detection brace.
Install the top screw [4] connecting the broken tool detection brace together.
Route the camera cable around the machine's enclosure panels into the control cabinet. Route the camera cable into the group of other routed cables behind the tool changer.
Install the camera cable into the camera.
Connect the camera cable 79-0159 [1] plugged into the USB adapter 74-2003 that connects into the USB port on the A62 processor.
Once the camera is installed, it is time to calibrate the camera. For more information on this, refer to the Broken Tool Detection - Calibration - AD0702 for more information.
