Bar Feeder 300 - Bar Loading Motor - Replacement
Service Home How To Procedures Bar Feeder 300 - Bar Loading Motor - Replacement
Recently Updated Last updated: 09/20/2018
- Jump to Section - 1. Bar Feeder 300 - Bar Loading Motor - Replacement (2 steps) Back to Top
Remove the Bar Transfer Table (V-tray) before you remove motor.
Disconnect the motor cables. Remove the (2) set screws [1] that lock the motor shaft to the clutch.
Remove the (4) bolts [1] that attach the motor to the chassis.
Pull the motor straight back. Make sure you do not lose the motor key.
Replace the motor. Install the components in the opposite order that they were removed.
