How To Load Activation or Time Extension Files to a Machine
Service Home How To Procedures How To Load Activation or Time Extension Files to a Machine
2.1 How to Load Activation or Time Extension Files to a machine
Recently Updated Last updated: 10/28/2024
Revision A - 4/2025
Note: This procedure is for NGC machines with 100.24.000.1120 and higher.
 Important: This procedure is intended to be done by a customer. These instructions are intended to help the customer understand the process and what information they need to give to the Haas Factory Outlet (HFO).
 Note: Machines with 100.24.000.1111 and older should follow the instructions on Activation Codes (100.24.000.1111 and older).
This procedure needs to be done under the following circumstances
  1. Machine time extension.
  2. Option code unlocks that do not require a patch file.
How To Generate an Out File.
Starting with software version 100.24.000.1120, a new way of applying activation and option codes will be implemented. From this version forward, if new activation or option codes need to be added to the control, the following two-step process will need to be followed.
1. Generate an "OUT" file on the control and give the "OUT" file to your local HFO.
The OUT file contains all the information necessary to generate codes for a machine. OUT files are specific to individual machines.
2. Your HFO will generate an EMC file from the "OUT" file. Load the EMC file onto your CNC machine's control to apply the activation codes.
Detailed instructions on how to do these two steps can be found below.
Insert a UBS stick into the control pendant.
Press [Diagnostics] -> navigate to the Parameters tab -> Activation sub tab.
Press [F2] to generate an OUT file.
[2] Indicates how much time until the next machine generated code is generated. Codes will only last 4 days. Once a machine generated code has expired, all previously generated OUT or EMC files will no longer be valid.
 Warning: Do not power cycle the machine until the EMC file has been loaded. The machine generated code will reset if the machine is power cycled.
Press [1] to save the Out file to our USB stick.
Send the OUT file to your HFO so they can generate an EMC file to load onto the control.
Note: The name of the out file has three parts.
[2] The serial number of the machine it was taken.
[3] The date the File was generated.
[4] The time the File was generated.
How To Load an EMC File Onto a Control
 Important: This procedure is intended to be done by a customer. These instructions are intended to help the customer understand the process and what information they need to give to the HFO.
Load the EMC file to a USB stick.
Note: The name should not be edited, or the control may not recognize it and fail to load the EMC.
[1] The serial number of the machine it was taken.
[2] The date the File was generated.
[3] The time the File was generated.
Press [F3] to load the EMC file to the control.
Press [1] to select to load via USB.
Press highlight the correct EMC file and press [ENTER] to load the file onto the control.
