Tooling - Maintenance - Mill
Service Home How To Procedures Tooling - Maintenance - Mill
Recently Updated Last updated: 11/30/2018
- Jump to Section - 1. Tooling - Maintenance (3 steps) Back to Top
Dirty, rusted or damaged toolholders may damage the spindle taper. Before you load a tool into the spindle, be sure to clean and repair the toolholder's taper.
Use a scouring pad [2] to remove light rust and dirt. Use a soft stone [3] to repair small dings or high spots on the taper[1].
Clean the toolholder with a lint-free cloth. Examine cutting tools to make sure that they are not worn or damaged [4]. Inspect the retention knob [5] (pull stud) for damage, wear, and proper torque.
 Note: Apply a light coat of grease to the retention knob [5] monthly to lubricate the drawbar. If you use through-spindle coolant (TSC), apply grease to the retention knobs weekly.** Retention knobs have a service life of approximately 6000-8000 hours of use. Failure to change the retention knob can result in toolholder and spindle damage if the retention knob breaks.
Toolholder Damage from a Broken Retention Knob.
To help protect the spindle taper from damage, refer to the VMC - Spindle - Taper - Maintenance procedure.
  Note: The recommended intervals to apply grease to the retention knobs are based on the average user. Adjust your maintenance schedule as needed to keep the retention knobs properly greased.
