Pocket - Solenoid - Replacement - VMC
Service Home How To Procedures Pocket - Solenoid - Replacement - VMC
Recently Updated Last updated: 01/04/2019
- Jump to Section - 1. Replacement 2. MAC - Solenoid Configuration 3. Festo - Solenoid Configuration Back to Top
Replacement
The service part P/N 32-5660; SOLENOID, VALVE 2W/2P M-CONNECTOR is the replacement solenoid assembly for the pocket up/down solenoid (does not include fittings). These assemblies use solenoids from different manufacturers. The solenoid assemblies are different in appearance and configuration for machines made in different years. This can cause confusion when you replace this assembly.
Each of the solenoid assemblies have the same cable connectors. Use the fittings from the removed assembly to make the correct configuration for your machine. Refer to the images below:
Note: Part numbers may change due to availability, please check with your local Haas Distribuitor for availability.
  1. 58-3075 FITTING, POLY1/4M NPT1/8F 90 BRASS
  2. 58-3050 FITTING, LBO-1/4 X NPT-1/8-M X 90
  3. 58-16732 FITTING, NIPPLE 1/8 NPT HEX BRASS PARKER 21
  4. 58-2754 VALVE, CHECK NPT-1/8-F X NPT-1/8-F BRASS
  5. 20-5630 NIPPLE, NIPPLE HEX 1/8 NPTM X 3/8 SMOOTH
  6. 58-0093 FITTING, NPT1/8F NPT1/8M ORIFICE .081 STR (damper fitting)
  7. 58-1865 FITTING NPT1/8M MUFFLER FREE FLOW
  3. 58-2080 FITTING NPT1/8F NPT1/8M ORIFICE .070 STR
  4. 58-1865 FITTING NPT1/8M MUFFLER FREE FLOW
  5. 58-16732 FITTING, NIPPLE 1/8 NPT HEX BRASS PARKER 21
  6. 58-2754 VALVE, CHECK NPT-1/8-F X NPT-1/8-F BRASS
  7. 20-5630 NIPPLE, HEX 1/8 NPTM X 3/8 SMOOTH
  8. 58-0093 FITTING NPT1/8F NPT1/8M ORIFICE .081 STR (damper fitting)
  9. 58-1865 FITTING NPT1/8M MUFFLER FREE FLOW
