Renishaw Probe - WIPS - OTS - Settings
Service Home How To Procedures Renishaw Probe - WIPS - OTS - Settings
Recently Updated Last updated: 05/06/2025
Applies to machines built from: January, 2000
The probe has (3) LEDs. This lets you see one of the LEDs from each side of the probe. The (3) LEDs operate as one. The LEDs flash in different colors and different lengths of time. The sequence that the LED flashes tells you the probe settings.
The LEDs flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
  • Purple
The LEDs flashes a short or a long time. In the tables that follow, a small colored circle shows that the LED flashes a short time . A rectangle shows that the LED flashes a long time .
Look at the probe LEDs. Record the color and length of time that the LED flashes.
The meaning of the color and the length of time that the LED flashes is important. Refer to the table for the meaning.
The probe settings are in (3) groups,
  1. Enhanced Trigger Filter.
  2. Probe Identification.
  3. Optical Power.
LED Check
The LED flashes in this sequence: Probe State:
, ,  The LEDs operate correctly.
, ,  The trigger filter is off. This is the initial setting for Haas machines.
, ,  The trigger filter is on
, ,  Probe 1 is active. Usually the spindle probe is probe 1.
, ,  Probe 2 is active. Usually the table probe is probe 2. This is the initial setting for Haas machines.
, ,  Probe 3 is active.
Optical Power
, ,  The optical power level is set to the low power level. This is the initial setting for Haas machines.
, ,  The optical power level is set to the standard power level.
Battery Status
, , , ,  The battery is good.
, , , , , , , , ,  The battery is low.
