Simulator - HDMI Display Mode - NGC
Service Home How To Procedures Simulator - HDMI Display Mode - NGC
Recently Updated Last updated: 07/23/2020
Revision 1
- Jump to Section - 1. Introduction 2. Simulator with A62 Main Board PCB (1 step) 3. Simulator with Q7 Maincon PCB (1 step) 4. Power On in HDMI Mode Back to Top
This procedure will show you how to connect your simulator to a HDMI monitor device.  This will allow you to view the simulator display on a TV, PC monitor, projector, etc.
Software Compatibility:
Software version 100.19.000.1200 or higher.
Power OFF the Simulator.
Remove the back cover.
Remove one of the empty plugs.  Feed the HDMI cable through the hole.
Connect a standard HDMI cable between the HDMi connector on the Main board and the HDMI monitor.
Connect a standard HDMI connector J4 on the Mainboard PCB.
Press and hold the 'H' key while booting for HDMI mode.
Note:  The next time the simulator or machine is powered on the simulator will boot into the standard display option.
