ST-20/20Y/25/25Y Sub-Spindle B-Axis Switch Relocation - AD0536
Service Home How To Procedures ST-20/20Y/25/25Y Sub-Spindle B-Axis Switch Relocation - AD0536
Recently Updated Last updated: 02/02/2023
AD0536
- Jump to Section - 1. Switch Removal (1 step) 2. Switch Install (2 steps) Back to Top
Switch Removal
PN: 93-3226 ST-20 B-AXIS SWITCH RELOCATION
1.  Remove the Motor Cover and remove the hardware for the Ball Screw Cover and Ball Screw Mount.
2.  Remove the hardware from the front of the Ball Screw Cover and pull the Cover forward to access the Switch Assembly.
3.  Unplug the home switch noting the connector locations and remove the Switch Assembly.
4.  Remove the Switch Flag.
Switch Install
1.  Install the new Switch Flag.
2.  Install the Switch and Grommet to the new Ball Screw Mount.
3.  Install the Switch Assembly and route the home switch cable through the grommet and connect the Home Switch connectors labeled NC and COM to the correct connectors on the home switch.
4.  Install the new Motor Cover.
1.  Slide the Ball Screw Cover back into place and install the Switch Cover.
2.  Install the Ball Screw Cover hardware.
Perform the Axis Grid Offset - NGC procedure for the B-Axis after installing the switch assembly.
