Chip Tray Strainer Kit - Installation - AD0099
Service Home How To Procedures Chip Tray Strainer Kit - Installation - AD0099
23.1 Chip Tray Strainer Kit
AD0099
Revision C - 2/2026
Updated
This procedure tells you how to install the coolant chip tray strainer. This filter removes very small particles (200-micron) from the coolant.
Machine Requirements:
  • Machines manufactured after 11/2011 with a 20-, 48-, 55-, or 95- gallon coolant tank.
Applicable service kits:
Required for machines built from 11/2011 - 10/27/2025:
 NOTE: The following service kits apply to machines built during this period:
  • 93-1001249 CHIP TRAY AND CLNT TANK FIELD INSTALL KIT
  • 93-1001014 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT
Required for machines built after 10/27/2025:
The following kits are used to replace the chip tray and/or strainer: These kits are not compatible with the previous strainer kit.
  • 93-1001245 CHIP TRAY FIELD INSTALL KIT
  • 93-1001240 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT
NOTE: As of 10/27/2025, only kit part numbers 93-1001245 and 93-1001240 are supported.
After this date, only Step 1 of this installation procedure is applicable.
Insert the chip tray filter screen 93-1001240 [1] into the coolant tank chip tray 93-1001245 [2].
Place the chip tray assembly into the coolant tank [3].
NOTE: The fitment for the new chip tray and strainer is the same as the previous iteration.
For service kits acquired between 11/2011 and 10/27/2025.
  • 93-1001249 CHIP TRAY AND CLNT TANK FIELD INSTALL KIT (1)
  • 93-1001014 SUPPLEMENTAL CHIP TRAY FIELD INSTALL KIT (2)
Put the strainer [A] across the top and around the sides of the wire basket [B].
Put the wire basket [B] into the clean chip tray [1].
Install the assembly [2] into the coolant tank.
