Umbrella Tool Changer - Carousel Plate - Replacement - AD0284
Service Home How To Procedures Umbrella Tool Changer - Carousel Plate - Replacement - AD0284
3.4 Umbrella Tool Changer - Carousel Plate - Replacement
AD0284
Revision B - 06/2026
Updated
This procedure will show you how to replace the carousel plate on a umbrella style tool changer.
Note: The carousel plate is heavy. You must have the aid of one more person to help you lift it.
This document applies to the following service kits:
  • 30-0017A    CAROUSEL COMPLETE, 20 POCKET CT50
  • 93-1000374    BT TO CT CONV UMB 10 PCKT 40T
  • 93-1000375    CT TO BT CONV UMB 10 PCKT 40T
  • 93-1000376    BT TO CT CONV UMB 20 PCKT 40T
  • 93-1000377    CT TO BT CONV UMB 20 PCKT 40T
  • 93-1718    CAROUSEL COMPLETE, 10 POCKET BT40 W/COVERS
  • 93-30-0006    CAROUSEL COMPLETE, 32 POCKET CT40  (VR-6-11)
  • 93-30-7100A CAROUSEL COMPLETE, 16 POCKET CT40
  • 93-8001    CAROUSEL COMPLETE, 20 POCKET CT40
  • 93-8001BT    CAROUSEL COMPLETE, 20 POCKET BT40
Remove all tools from the tool changer.
Put wooden blocks on the table. Put a bottle jack on the wooden blocks.
Jog the table below the center of the carousel plate.
Support the carousel plate with the bottle jack.
Push [POWER OFF].
Remove the (6) SHCS from the carousel plate.
With a second person remove the carousel plate.
If necessary remove the old cover plate [1] and install it on the new carousel plate [2].
With the aid of a second person, put the new carousel plate [2] and the cover plate [1] onto the bottle jack. While the second person balances the new carousel plate [2] on the jack, do these steps:
  • Lift the new carousel plate [2] to the threaded holes. Align the dowel pin [3] to the hole in the bearing housing.
  • Install the (6) 5/16-18 x 1" Socket Head Cap Screws (SHCS) [4].
Torque the screws to 25 ft-lbs.
Push [POWER ON].
Check the tool changer alignment. Refer to Umbrella Tool Changer to Spindle Alignment.
Install the tools.
