Integrated Linear Scale - Parameters - RD0032
Recently Updated Last updated: 10/16/2025
RD0032
Value for: Schneeberger 20 Readhead & Interpolation Box VF-x
Schneeberger 2X Readhead & Interpolation Box VF-x
Bosch-Rexroth MDC-1
Bosch-Rexroth VF-x
P266 X LIN SCALE EN
1 1 1 1
P266 X INVRT LN SCL
1 0 0 0
P266 X NEG COMP DIR
0 0 1 0
P267 Y LIN SCALE EN
1 1 1 1
P267 Y INVRT LN SCL
0 1 1 1
P267 Y NEG COMP DIR
1 1 1 1
P268 Z LIN SCALE EN
1 1 1 1
P268 Z INVRT LN SCL
1 0 1 1
P268 Z NEG COMP DIR
0 0 0 0
P125 X GRID OFFSET
Unique for each machine
P126 Y GRID OFFSET
P127 Z GRID OFFSET
P279 X LSC GAIN MULTIPLIER
40 40 40 40
P280 Y LSC GAIN MULTIPLIER
40 40 40 40
P281 Z LSC GAIN MULTIPLIER
40 40 40 40
P285 X LSC OFFSET
520000
520000
-200000
520000
P286 Y LSC OFFSET
-763000
-763000
-200000
-763000
P287 Z LSC OFFSET
590000
590000
250000
590000
P327 X LSC PER INCH
25400
25400
26010
26010
P328 Y LSC PER INCH
25400
25400
26010
26010
P329 Z LSC PER INCH
25400
25400
26010
26010
P333 X LSC PER REV (Z pulse)
50000
50000
51200
51200
P334 Y LSC PER REV
50000
50000
51200
51200
P335 Z LSC PER REV
50000
50000
51200
51200
Schneeberger integrated scales: Identify the readhead first. Do not replace a 2X Readhead with a 20 Readhead.   Change Interpolation Box DIP switch settings when necessary to match the Readhead in use per axis.
20 Readhead: Use Interpolation box #50-0019 and set the DIP switches: 1=off, 2=on, 3=on, 4=off, 5=on, 6=off, 7=off, 8=off.
2X Readhead: Use Interpolation box #50-0019A and set the DIP switches: 1=on, 2=off, 3=off, 4=off, 5=off, 6=on, 7=off, 8=off.
Bosch-Rexroth integrated scales: The readhead is not removable from the truck. Also, the interpolation electronics is integrated into the readhead. There are no dip switch settings to adjust.
*This parameter list and values show what was used as the machine was built. Always use the Parameter Checker program to analyze the parameters.
