Renishaw - WIPS - Optical Machine Interface (OMI) - Lights Information - RD0052
Recently Updated Last updated: 10/17/2025
Renishaw – WIPS - Optical Machine Interface (OMI) - Lights Information
RD0052
Overview
The probe has (7) LEDs. The LEDs flash in different colors and different lengths of time. The sequence that the LED flashes tells you the probe settings.
The LEDs flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
  • Purple
The LEDs flash a short or a long time. In the tables that follow, a small colored circle shows that the LED flashes a short time . A rectangle shows that the LED flashes a long time .
Look at the probe LEDs. Record the color and length of time that the LEDs flash.
The meaning of the color and the length of time that the LED flashes is important. Refer to the table for the meaning.
LED Table
Number in the Illustration LED Name LED Color This tells you this information:
1 Probe 1 Green  Probe 1 is active. Usually the spindle probe is probe 1.
2 Start signal status The LED flashes yellow  (1) time. A machine start signal is commanded.
The LED flashes yellow  many times. The system is set to Auto Start mode.
3 Low battery  Red  The Battery is low.
4 Probe Status Green  The probe is seated.
Red  The Probe is triggered or an error has occured.
5 Probe 2 Green  Probe 2 is active. Usually the table probe is probe 2.
6 Signal Strengh Green  The signal is good.
Yellow  The signal is weak or blocked.
Red  The probe does not receive the signal.
7 Error Red  The probe is not transmitting.
Blue  Refer to the user's guide.
Yellow  Refer to the user's guide.
Purple  Refer to the user's guide.
