Renishaw Probe – WIPS-RF - RMP40 – Settings - RD0054
Service Home Renishaw Probe – WIPS-RF - RMP40 – Settings - RD0054
Recently Updated Last updated: 10/17/2025
Renishaw Probe - WIPS-RF - RMP40 - Settings
RD0054
Revision A - 4/2025
Overview
The probe has (2) LEDs. The LEDs flash in different colors and different lengths of time. The sequence that the LEDs flash tells you the probe settings.
The LEDs flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
  • Cyan
  • Purple
The LEDs flash a short or a long time. In the tables that follow, a small colored circle shows that the LEDs flash a short time . A rectangle shows that the LEDs flash a long time .
Look at the probe LEDs. Record the color and length of time that the LEDs flash.
The meaning of the color and the length of time that the LEDs flash is important. Refer to the table for the meaning.
The probe settings are in (3) groups:
  1. Switch-Off Method
  2. Switch-On Method
  3. Enhanced Trigger Filter
LED Check
The probe does a check of the LED. It does this before it shows the values of the settings.
The LED flashes in this sequence: Probe State:
, , , , ,  The LED operates correctly.
Switch On Method
, ,  Switch on  method is set to radio on. This is the initial setting for Haas machines.
, ,  Switch on method is set to spin on.
Switch Off Method
, ,  Switch off method is set to radio or spin. This is the initial setting for Haas machines.
, ,  Switch off method is set to short timeout (12 seconds).
, ,  Switch off method is set to medium time out (33 seconds).
, ,  Switch off method is set to long timeout (134 seconds).
Enhanced Trigger Filter Setting
, ,  Enhanced trigger filter is set to OFF. This is the initial setting for Haas machines.
, ,  Enhanced trigger filter is set to on with a nominal 10 ms trigger delay.
, ,  Enhanced trigger filter is set to on with a nominal 20 ms trigger delay.
Pairing Mode
, ,  The pairing mode is off.
, ,  The pairing mode is off and the RMI-QE is found. (RMI-QE only)
, ,  The pairing mode is active.
, ,  Pairing was successful.
Operating Mode
, ,  The probe is seated in operating mode.
, ,  The probe is triggered in operating mode.
, , , , ,  The probe is seated in operating mode with a low battery.
, , , , ,  The probe is triggered in operating mode with a low battery.
The battery is dead.
, , , , , , ,   or
, , , , , , ,   or
, , , , ,  (sequenced when batteries are inserted)
The battery is unsuitable.
Battery Status
Probe State:
, , , ,  The battery is good.
, , , , , , , , ,   or   , , , , , , , , ,  The battery is low.
Battery Status
Probe State:
Master Reset
, , , , , , ,  The probe's previous settings have been cleared. The probe is reset to the default settings.
