Spindle Belt Tension Specifications - VMC - HMC - RD0066
Service Home Spindle Belt Tension Specifications - VMC - HMC - RD0066
Recently Updated Last updated: 10/17/2025
RD0066
If your spindle has a non-contact encoder - be sure to reset the encoder gap AFTER resetting the belt tension. Changing the belt tension will change the encoder gap. If the gap is not reset it is possible the machine will generate alarms or worst case it will permanently damage the encoder ring or read head.
Model, Drive RPM Weight Width Span Tension
Toolroom Mill, MiniMill, Super MiniMill 4,000-10,000 4.7 21
MM/TM:186
Super MM: 194
Gates: 40-50 Lbf (178-222 N)
Continental: 35-40 Lbf (156-178 N)
Delta: 40-50 Lbf (178-222 N)
GR-510 / 712 10,000 4.7 21 194
Gates: 45-50 Lbf (200-222 N)
Megadyne: 75-80 Lbf (334-356 N)
Office Mill / Compact Mill 30,000-50,000 2.8 15 97 165-175 Hz
40 Taper, Direct Drive, 7.5k 7,500 4.7 18 226 33-37 Lbf (147-165 N)
40 Taper, Direct Drive, 10k/15k 10,000 - 15,000 4.7 18 234 33-37 Lbf (147-165 N)
40 Taper, Transmission, 7.5k/10k 7,500 - 10,000 4.7 18 226 45-50 Lbf (200-222 N)
50 Taper, Transmission, VMC 7,500 - 10,000 4.7 21 330 45-50 Lbf (200-222 N)
50 Taper, Transmission, HMC 7,500 - 10,000 4.7 21 250 33-37 Lbf (147-165 N)
30 Taper 30K 30,000 4.1 25 209 50-58 Lbf (222-258 N)
