Toolroom Mill Maintenance Schedule - RD0075
Service Home Toolroom Mill Maintenance Schedule - RD0075
Recently Updated Last updated: 10/17/2025
RD0075
- Jump to Section - 1. Introduction Back to Top
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. This page shows the recommended maintenance intervals.
Maintenance Item Interval
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Axis Lubrication
Inspect oil reservoir level.
Monthly
Six Months
Perform an Axis Lubrication Test. Six Months
Ballscrews/Linear guides equipped with zerk fitting Monthly or weekly if cutting absorbent materials
Inspect windows for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Minimum Quantity Lubrication
Clean the filter inside the oil reservoir.
Annually
Inspect the oil skimmer pickup tube.
Six Months
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Probe System
Check the probe batteries.
Six Months
Check probe calibration.
Six Months
Inspect the oil level.
Annually
Replace the oil.
Two Years
Inspect the A-Axis counterbalance cylinder for oil leaks. Two Years
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Clean the standard coolant filter.
Six Months
Verify coolant refill is operating correctly.
Six Months
Spindle
Clean and lubricate the spindle taper.
As Required
Spindle drawbar force measurement.
Annually
Spindle Lubrication
Inspect lubrication tank level.
Monthly
Perform Spindle Lubrication Test.
Six Months
Tooling
Grease Pull Studs.
As Required
