CL-1 Drawtube Clamping Improvement
Service Home Service Alerts/News CL-1 Drawtube Clamping Improvement
November 14, 2018 CL-1 Drawtube Clamp Improvement
Haas has released a new service kit 93-2945 to address clamping problems with the CL-1.
If you are experiencing problems with the collet style closer, please order and install this kit
The kit will include the following:
  • 1 ea Bracket spring
  • 6 shim washers
  • New dowel pins for the clamp arm
  • washers for mounting
Install the kit as follows:
Replace dowel pins
  1. Press out and install new dowel pins on the clamp arm
  2. The 2" long dowel should be placed on the side of the clamp arm that engages the clamp switch
  3. When pressing the dowels into place, use 2 of the 3/8' black oxide washers as a height gauge so that the dowel extends 1/4" towards the spindle shaft
Install and shim spring
  1. Remove the switch mounting bolt and install the shims, spring, and black oxide washer as shown in the attached image
  2. Place 3 shims between the spring and the switch block
  3. Torque the main mounting bolt to 45 ft lbs
  4. Clamp the collet and check to make sure the dowel pins are not contacting drawbar locking collet
  5. Adjust the amount of shims between the spring and the switch block until the dowels do not contact the locking collet
Reference this video for more information
