      • Taschenfräsen
      • Konsolfräsmaschinen
      • Manuelle Drehmaschine
      • Vertikalsäge
      • Gehrungssäge
    • Taschenmaschinen
      Taschenmaschinen
      • Taschenmaschinen
      • Taschenfräsen
      VF-Super-Speed - Super Features Come Standard! | Haas CNC Alles anzeigen
      UMC-Super-Speed - Super Features Come Standard! | Haas CNC Alles anzeigen
      ST-Y-Axis Standard Features | Haas CNC Alles anzeigen
      • Flexible Honbürsten
      • Werkzeugtaschen
Flexible Honbürsten
Werkzeugtaschen
END MILL HOLDERS
HAAS TESTED. HAAS PROVEN.
  2. Werkstückhalterung für Fräsen
  3. Vise Kits
HAAS MAKES WORKHOLDING EASIER
COMPLETE INDUSTRY-TESTED MILL WORKHOLDING KITS, AT AFFORDABLE PRICES!
______________________________________________________________________________
Our pre-configured Vise Kits are your complete workholding solution. All our kits comes with everything you need to start using them immediately.
      Single-Station, Fixed-Jaw
Haas fixed-jaw vises are a single-station design, with one stationary jaw and one moveable jaw. These manual milling vises provide secure workpiece clamping and accurate positioning for all machining operations. The simple bolt-on jaws are easily changed or reversed, without disassembling the vise, and the jaws can be attached to the outside ends of the jaw plates to accommodate larger workpieces. Replacement hard jaws, as well as machinable steel and aluminum soft jaws are available.
Each vise includes a vise handle, and all necessary mounting hardware: toe clamps, mounting bolts with flange nuts and T-slot nuts, and alignment keys.
  • Extra-wide opening
  • One-piece ductile iron body, HRC 45
  • Precision-ground sides allow side mounting (except flange-style)
  • Angle-lock system reduces jaw lift
  • Fixed height simplifies multi-vise setups
Self-Centering
Haas self-centering vises feature compact, low-profile designs that automatically adjust the workpiece to the center of the vise for increased precision and repeatability. The simple bolt-on or drop-in jaws (depending on model) are easily changed or reversed, and feature a 45° dovetail and serrated gripping surfaces. The serrated teeth provide maximum grip on non-hardened materials, while the dovetail provides maximum clamping force for hardened materials, while providing access to five sides of the part. Replacement jaws and inserts are available, including machinable steel and aluminum soft jaws.
  • Compact design
  • Hardened-steel jaws or inserts, with a 45° dovetail and serrations
  • Tool steel construction
  • Replacement hard and soft jaws and inserts available
  • High-accuracy repeatability
* Haas by Kurt and Haas by Jergens vises currently do not include mounting hardware.
Workholding VIDEOS
Artikel
Preis: Niedrig bis hoch Preis: Hoch bis niedrig
HINZUFÜGEN EINER WERKSTÜCKHALTERUNG ZU IHRER CNC
SO GING MAN FRÜHER VOR
  • Studieren umfangreicher komplexer Kataloge auf der Suche nach der richtigen Werkstückhalterung, oder vielmehr einer, von der man zumindest glaubt, dass man sie benötigt …
  • Bestellen der Werkstückhalterung bei einem Anbieter — manchmal bei einem Werkzeughändler, manchmal beim Hersteller.
  • Suche nach den benötigten Adaptern für Ihre Maschine und die Werkstückhalterung und Bestellung bei einem anderen Anbieter, es sei denn, Sie haben das Glück, dass der Werkzeughändler sowohl Werkzeughalterung und Adapter vorrätig hat.
  • Warten auf das Eintreffen der Lieferungen der Teile von mehreren Anbietern mit unterschiedlichen Lieferzeiten.
  • Zusammenbauen und hoffen, dass alles funktioniert.
AUF HAAS IST VERLASS
  • Gehen Sie auf HaasTooling.com
  • Finden Sie Ihre Werkstückhalterung (PROFI-TIPP: Wählen Sie einen kompletten Werkzeughalterungssatz von Haas. Er enthält alles, was Sie brauchen — zu einem vernünftigen Preis —, und geben Sie nur eine einzige Bestellung auf).
  • Alles wird bis zu Ihrer Tür geliefert. Sämtliche erforderliche Information und Hilfestellung (inklusive Videos!) sind auf HaasTooling.com abrufbar.
VON HAAS HERGESTELLT
WERKSTÜCKHALTERUNG LEICHTGEMACHT MIT HAAS
