VS-3
  1. Vertical Mills
  2. Extra-Large VMC
  3. VS-3
VS-3
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
Vertical Machining Center; 150" x 50" x 50" (3810 x 1270 x 1270 mm)
The Haas VS-3 is a large-frame, bed-style machining center that provides large travels and heavy-duty cutting capacity in a vertical spindle format. The machine features a 50-taper, geared-head spindle and a 50+1 tool side-mount tool changer. The fully supported X-axis travels easily handle parts weighing up to 10,000 lb (4536 kg). The table surface consists of three blank tooling plates that are easily machined for custom fixturing.
NOTE: A T-slot table can be subsituted for the tooling plate table at the time of order.
  • 50+1 side-mount tool changer
  • Fixed enclosure; does not move with the table
  • 4 chip augers, with available in-tank conveyor
  • Control pendant on moveable stand for easy access
  • Fully supported X-axis travel
  • 50 mm ballscrews on all axes
  • 10,000 lb (4536 kg) part capacity
  • 153" x 49" (3886 x 1245 mm) table, with 3 blank bolt-on tooling plates for custom fixturing
See Available Stock
Current Lead Time
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Rotary Fit Chart
Travels S.A.E METRIC
X Axis 150.00 in 3810 mm
Y Axis 50.00 in 1270 mm
Z Axis 50.00 in 1270 mm
Spindle Nose to Table (~ max) 55.0 in 1397 mm
Spindle Nose to Table (~ min) 5.0 in 127 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Taper CT or BT 50 CT or BT 50
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Table S.A.E METRIC
Length 153.0 in 3886 mm
Width 49.0 in 1245 mm
Thickness 1.9 in 48 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Feedrates S.A.E METRIC
Max Cutting 360 ipm 9.1 m/min
Rapids on X 360 ipm 9.1 m/min
Rapids on Y 600 ipm 15.2 m/min
Rapids on Z 600 ipm 15.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4000 lbf 17793 N
Max Thrust Y 4000 lbf 17793 N
Max Thrust Z 6300 lbf 28024 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full)** 4.0 in 102 mm
Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
Max Tool Length (from gage line) 16.00 in 406 mm
Max Tool Weight 30.0 lb 13.6 kg
Tool-to-Tool (avg) 6.00 s 6.00 s
Chip-to-Chip (avg) 15.00 s 15.00 s
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 7500 rpm 7500 rpm
Spindle Power 30.0 hp 22.4 kW
Domestic Pallet for Sheet Metal Crate 89 in x 57 in x 50 in 226 cm x 145 cm x 127 cm
Weight for Sheet Metal Crate 720 lb 326 kg
Domestic Pallet, Column Assembly 180 in x 102 in x 146 in 457 cm x 259 cm x 370 cm
Domestic Pallet, Table Assembly 376 in x 82 in x 99 in 955 cm x 208 cm x 251 cm
Weight, Column Assembly, Domestic 23,060 lb 10,460 kg
Weight, Table Assembly, Domestic 22,580 lb 10,242 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
VIDEOS
RELATED PRODUCTS
Standard Features
  • 7500-rpm Spindle
  • 50+1 Side-Mount Tool Changer, 50-Taper
  • Chip Auger
  • Window Air Blast
  • 95-Gallon Coolant Tank
  • Chip Tray Filter Kit
  • Multi-Stage Coolant Pump
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • CNC Control Cabinet Cooler
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Rigid Tapping
  • ECO Mode
  • Stainless Steel Way Covers
  • Phone Charging Stand
  • Machine Anchoring Kit
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • INSTALLATION Guide
  • Layout Drawing
  • Operator’s Manual
VIDEOS
VS-3 Cutting Demo
Our large-frame 50-taper VMC gives the ultimate flexibility for large and heavy parts. It provides 150" x 50" x 50" (3810 x 1270 x 1270 mm) travels, heavy-duty cutting capacity, and a massive table that handles parts up to 10,000 lb.
VS-3 Installation
Haas Machines are used in our very own factory, including the VS-3, to make the same high-quality machine tools you know. See how Orville and Eugene install, level, and align the newest addition to our machine shop.
High-Performance 50-Taper Spindle
Do you need to increase your material removal rates? Our high-performance 50-taper spindle options use a powerful 60 hp (44.7 kW) vector drive system to push the boundaries to new limits. If you want to cut more chips in less time, watch now to see how we can maximize your material removal rates!
RELATED PRODUCTS
C-Frame VMC
Haas VF-14/50
VF-14/50
CNC Vertical Mill with 150" x 40" x 30" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Different Approach
Haas GM-2
GM-2
3-Axis CNC Gantry Mill with 145" x 87.5" x 22" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
    CNY ONLY
HRT450 VS-3 POSITIVE FIT
HRT630 VS-3 POSITIVE FIT
HRT800 VS-3 POSITIVE FIT
TR310 VS-3 POSITIVE FIT
TR500SS VS-3 POSITIVE FIT
HRT1000 VS-3 POSITIVE FIT
HRT210VM VS-3 POSITIVE FIT
HRT200HS VS-3 POSITIVE FIT
Build & Price
Get Started
Need More Information?
