VM-3/50
  1. Vertical Mills
  2. Mold Machines
  3. VM-3/50
VM-3/50
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
50-Taper CNC Vertical Mold Machine with 40" x 26" x 25" travels
The Haas VM Series machines are high-performance VMCs that provide the accuracy, rigidity, and thermal stability required for mold making, tool & die work, and other high-precision industries.
Our 50-taper VM models feature a generous work cube, a multi-fixturing table, and a high-power 10,000-rpm gearbox spindle. Standard features include the Haas high-speed control with full look-ahead, a side-mount tool changer, a programmable coolant nozzle, an automatic air gun, and much more.
  • 10,000-rpm gearbox spindle, 60 hp (44.7 kW)
  • Side-mount tool changer
  • Multi-fixturing table
  • High-speed machining software
See Available Stock
Current Lead Time
  • 50 Taper
  • 3 Axis
  • 10k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
VM SERIES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Automation
    • Machine Info
    • Rotary Fit chart
    Travels S.A.E METRIC
    X Axis 40.00 in 1016 mm
    Y Axis 26.00 in 660 mm
    Z Axis 25.00 in 635 mm
    Spindle Nose to Table (~ max) 32.9 in 836 mm
    Spindle Nose to Table (~ min) 7.9 in 200 mm
    Spindle S.A.E METRIC
    Max Rating 60.0 hp 44.7 kW
    Max Speed 10000 rpm 10000 rpm
    Max Torque 350.0 ft-lbf @ 900 rpm 475.0 Nm @ 900 rpm
    Drive System 2-Speed Gearbox 2-Speed Gearbox
    Taper CT or BT 50 CT or BT 50
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Coolant Jacket Coolant Jacket
    Table S.A.E METRIC
    Length 54.0 in 1372 mm
    Width 24.5 in 622 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 3.94 in 100 mm
    Number of Std T-Slots 13 in Y and 6 in X 13 in Y and 6 in X
    Max Weight on Table (evenly distributed) 4000 lb 1814 kg
    Feedrates S.A.E METRIC
    Max Cutting 500 ipm 12.7 m/min
    Rapids on X 710 ipm 18.0 m/min
    Rapids on Y 710 ipm 18.0 m/min
    Rapids on Z 710 ipm 18.0 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 4100 lbf 18238 N
    Max Thrust Y 4100 lbf 18238 N
    Max Thrust Z 5600 lbf 24910 N
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty)** 7.0 in 178 mm
    Max Tool Length (from gage line) 16.00 in 406 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 4.20 s 4.20 s
    Chip-to-Chip (avg) 6.30 s 6.30 s
    General S.A.E METRIC
    Coolant Capacity 55 gal 208 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 10000 rpm 10000 rpm
    Spindle Power 60.0 hp 44.7 kW
    Full Load Amps (3 Phase) - Low 105 A 105 A
    Domestic Pallet 156.0 in x 102.0 in x 105.0 in 397 cm x 260 cm x 267 cm
    Export Pallet 164.0 in x 91.5 in x 101.0 in 417 cm x 233 cm x 257 cm
    Weight 12720 lb 6940.0 kg
    Domestic Pallet w/50+1 SMTC 156 in x 102 in x 125 in 397 cm x 260 cm x 318 cm
    Export Pallet w/50+1 SMTC 164 in x 92 in x 101 in 417 cm x 233 cm x 257 cm
    Weight w/50+1 SMTC 15600 lb 7077 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    Standard Features
    • High-Performance 10,000-rpm Spindle
    • 30+1 Side-Mount Tool Changer, 50-Taper
    • Programmable Coolant Nozzle
    • Automatic Air Gun
    • Chip Auger
    • Window Air Blast
    • 55-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Multi-Stage Coolant Pump
    • Chip Washdown Feature
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • High-Speed Machining
    • Rigid Tapping
    • User-Definable Macros
    • Coordinate Rotation and Scaling
    • Internal High-Voltage Isolated Transformer
    • ECO Mode
    • Table Auxiliary Air Supply
    • Stainless Steel Way Covers
    • Phone Charging Stand
    Shipping
    • Lifting Provision
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
    SPACE EFFICIENT
    COST EFFECTIVE
    EASY TO INTEGRATE
    EASY TO LEARN
    AVAILABLE OPTIONS
    VIDEOS
    RELATED PRODUCTS
    Standard Features
    • Automatic Air Gun
    • Chip Auger
    • Window Air Blast
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    Shipping
    • Lifting Provision
    Warranty
    Available Options
    Automation Options
    • 3D Model (ZIP) (Coming Soon)
    • Installation Guide
    • Layout Drawing (Coming Soon)
    • Torque Chart
    • Operator’s Manual
    Videos
    Through-Tool Air Blast – TAB
    Haas TAB functions just like through-spindle coolant, except uses a high-pressure, high-volume blast of air. When you can’t use coolant, but need to clear those chips, check out TAB.
    Minimum Quantity Lubrication System
    Can’t use water-based coolant on your parts . . . but still need to keep your cutting tools lubricated? The Haas Minimum Quantity Lubrication System can help you out.
    Avoiding a Crash
    In this Haas Tip of the Day, Mark gives some pointers on using settings in the Haas control to keep from breaking your tool – or worse!
    How to Start A Job in the Middle of A Program
    Have you ever had your power go out right in the middle of your program? Or maybe you broke a tool, or needed to change an insert, or wanted to inspect your part during the finish pass. With Haas’ Program Restart, it’s no problem!
    RELATED PRODUCTS
    40-Taper Version
    Haas VM-3
    VM-3
    • 40 Taper
    • 3 Axis
    • 12k RPM
        CNY ONLY
    Learn More Build & Price
    Smaller Work Envelope
    Haas VM-2
    VM-2
    CNC Vertical Mold Machine with 30" x 20" x 20" travels
    • 40 Taper
    • 3 Axis
    • 12k RPM
        CNY ONLY
    Larger Work Envelope
    Haas VM-3
    VM-5/50
    50-Taper CNC Vertical Mold Machine with 50" x 26" x 25" travels
    • 50 Taper
    • 3 Axis
    • 10k RPM
        CNY ONLY
    HA2TS VM-3/50 POSITIVE FIT
    HA5C VM-3/50 POSITIVE FIT
    HA5C2 VM-3/50 POSITIVE FIT
    HA5C3 VM-3/50 POSITIVE FIT
    HA5C4 VM-3/50 POSITIVE FIT
    HA5CS VM-3/50 POSITIVE FIT
    HRC160 VM-3/50 POSITIVE FIT
    HRC210 VM-3/50 POSITIVE FIT
    HRT160 VM-3/50 POSITIVE FIT
    HRT160-2 VM-3/50 POSITIVE FIT
    HRT160SP VM-3/50 POSITIVE FIT
    HRT160SS VM-3/50 POSITIVE FIT
    HRT210 VM-3/50 POSITIVE FIT
    HRT210M VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HRT210SP VM-3/50 POSITIVE FIT
    HRT310 VM-3/50 POSITIVE FIT
    HRT310SP VM-3/50 POSITIVE FIT
    HRT450 VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HRTA5 VM-3/50 POSITIVE FIT
    HRTA6 VM-3/50 POSITIVE FIT
    T5C VM-3/50 POSITIVE FIT
    T5C2 VM-3/50 POSITIVE FIT
    T5C3 VM-3/50 POSITIVE FIT
    T5C4 VM-3/50 POSITIVE FIT
    TR160 VM-3/50 POSITIVE FIT
    TR160-2 VM-3/50 POSITIVE FIT
    TR200Y VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    TR210 VM-3/50 POSITIVE FIT
    TR310 VM-3/50 POSITIVE FIT
    TRT100 VM-3/50 POSITIVE FIT
    TRT210 VM-3/50 POSITIVE FIT
    TRT70 VM-3/50 POSITIVE FIT
    TRT160 VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HRT100 VM-3/50 POSITIVE FIT
    HRT210HT VM-3/50 POSITIVE FIT
    TH450 VM-3/50 POSITIVE FIT
    HRT210SS VM-3/50 POSITIVE FIT
    TH240 VM-3/50 POSITIVE FIT
    HA5C-T VM-3/50 POSITIVE FIT
    HA5C3-T VM-3/50 POSITIVE FIT
    HA5C4-T VM-3/50 POSITIVE FIT
    TRT310 VM-3/50 POSITIVE FIT
    HRT310SS VM-3/50 POSITIVE FIT
    HA5C2-T VM-3/50 POSITIVE FIT
    LT350 VM-3/50 POSITIVE FIT
    HRT210-2 VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    LT260 VM-3/50 POSITIVE FIT
    HRT210VM VM-3/50 POSITIVE FIT
    HRT200HS VM-3/50 POSITIVE FIT
    HQDA5 VM-3/50 POSITIVE FIT
    HQDA6 VM-3/50 POSITIVE FIT
    HRT210S VM-3/50 POSITIVE FIT
    HDD255 VM-3/50 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    Build & Price
    Get Started
    Need More Information?
