HFL-1313-3 Install Guide
PRE-INSTALLATION [GUIDE]
    CNY ONLY
Haas Compact Fiber Laser Cutting Machine, 3 kW
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Air / Electrical / Shipping
  • Additional Resources
Pre-Installation Checklist
NOTICE OF ADDITIONAL INSTALLATION COSTS
Installation costs for Haas HFL Series laser cutting machines are quoted separately from the machine purchase price. Because each site and setup is different, final installation costs may vary based on equipment needs, site preparation, utilities, rigging, training, and other required services.
Your local Haas Factory Outlet will review and confirm any installation-related charges with you before scheduling the installation.
  • Make sure that your floor is correct for the machine. Refer to the “Placement and Preparation” section in this document for more information.
  • Schedule the installation date and time. Tell your HFO so they can send a technician.
Click here to view the step-by-step installation procedure guide of your machine.
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient.
Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
For best cutting performance, Haas recommends anchoring your machine.
Available Anchoring Kits:
HFL-3015: 93-1001344
HFL-1313: 93-1001358
☑ Machine Placement
☑ Optional Component Location
  • Main Power Transformer – You must have space to remove and install the transformer.
  • Voltage Regulator – You must have space all around the regulator and especially the rear to access the power switch.
  • Servo Transformer – You must have space to remove and install the transformer.
  • Water Chiller – You must have space all around the chiller for ventilation and maintenance.
  • Laser Power Source Cabinet – You must have space all around the cabinet for ventilation and maintenance.
  • Electrical Enclosure (HFL-1313 models) – You must have space in front of and behind the enclosure for maintenance.
  • Dust Collector – You must have space around three sides of the dust collector for maintenance access.
Layout Drawing
Download Machine Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
Refer to the lifting placard on the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
Air Requirements | Electrical Specs | Shipping Dims
Air Requirements
S.A.E
Metric
Air Required
230 psi, 53 cfm
1.58 MPa, 1.5 m3/min
Inline Air Hose
0.472" OD
12 mm OD
Air Pressure Min
100 psi
6.9 bar
Electrical Specifications
208VAC Incoming
380 VAC Incoming
Machine
208VAC, 60Hz, 3 Phase, 90 A
380VAC, 60Hz, 3 Phase, 49 A
Main Transformer
Not Required
Voltage Regulator
380VAC, 60Hz, 3 Phase, 76 A
Servo Transformer
380VAC, 60Hz, 3 Phase, 15 A
Water Chiller
380VAC, 60Hz, 3 Phase, 17 A
Laser Power Source
380VAC, 60Hz, 3 Phase, 22 A
Dust Collector
380VAC, 60Hz, 3 Phase, 11 A
208VAC Operation with Included Main Transformer
380VAC Operation Does Not Require Main Transformer
Shipping Specifications SAE Metric
Machine Dimensions 123.5" x 90" x 88" 3140 x 2285 x 2235 mm
Dust Collector Dimensions 64.5" x 58" x 93.5" 1640 x 1475 x 2375 mm
Accessories Pallet Dimensions 90" x 45" x 68" 2285 x 1145 x 1725 mm
Servo Transformer Dimensions 24" x 21" x 30" 610 x 535 x 760 mm
Laser Source Cabinet Dimensions 50" x 38" x 39"  1270 x 965 x 990
Electrical Cabinet Dimensions 44" x 35.5" x 68" 1120 x 900 x 1725 mm
Machine Weight 4820 lb 2186 kg
Dust Collector Weight 1400 lb 635 kg
Accessories Pallet Weight 2240 lb 1016 kg
Servo Transformer Weight 280 lb 127 kg
Laser Source Cabinet Weight 380 lb 172 kg
Electrical Cabinet Weight 580 lb 263 kg
Air Requirements for Haas Lasers
Chiller Water
HFL Series Fiber Cutting Lasers are equipped with a water chiller to regulate the temperature of the laser source and laser cutting head.
Caution: Do not use tap water in chiller. The mineral composition can cause damage to the internal circuitry of the chiller, laser power source, and laser cutting head. Make sure to use deionized, distilled, or purified water only.
Note: Be sure to maintain your water tank to acceptable levels. Improperly maintained water levels can allow machine components to overheat.
Electrical Requirements for Haas Lasers
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
Ground
Wire Size
Service Breaker
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
