Air-Oil Blast, SR-P Series (AIR-OIL BLAST)
Product Image
GET QUOTE
    CNY ONLY
Delivers oil mist to the cutting tool
This Air-Oil Blast for the SR Series P models delivers a steady blast of compressed air and a small quantity of cutting oil to provide lubrication, reduce heat, and remove chips. This extends tool life, improves surface finish, and eliminates the need for coolant when cuttng metallic materials. The air-oil blast is activated via M-codes in the program, or manually from the control pendant. The mixture is adjusted manually via knobs on the air-oil manifold, and delivered through a flex line that can be directed at the cutting tool.
  • Provides lubrication when machining metals
  • Activated via M-codes, or manually from the control pendant
  • Mixture is manually controlled at the air/oil manifold
  • Adjustable flex line to deliver air/oil mixture to the cutting edge
DOCUMENTS
AVAILABLE ON THESE MACHINES
Service Documents
Need More Information?
