In-Tank Chip Conveyor, DC (CONVINTANK DC)
Product Image
GET QUOTE
    CNY ONLY
Belt-type conveyor discharges chips at standard barrel height
  • Option Info
  • Details
OVERVIEW
AVAILABLE ON THESE MACHINES
This heavy-duty steel, belt-type chip conveyor sits in the machine’s coolant tank, where it collects chips as they exit the machine, and discharges them at standard industrial barrel height. It is ideal for high-production machining applications, and can be activated via M-code, or directly from the control pendant. There are settings to control the interval and duration of the conveyor cycle for automatic operation, and the system automatically reverses if a jam occurs.
  • Fast removal of chips
  • Ideal for a high-production environments
  • Automatic reversal upon torque overload situations
  • Activated by M-code, or manually from the control pendant
  • User settings to control cycle interval and duration for automatic operation
Chip Conveyor
Chips and Coolant Conveyor. Product of Haas CNC machine tools.
Our belt-style chip conveyor automatically removes chips from the machine, while discharging them at standard barrel height. The chip chute’s steep lift angle minimizes coolant carryout.
  • Automatically reverses if a jam occurs
  • Activated via M-code, or from the control pendant
  • Settings control the interval and duration of operation
  • Automatic operation increases energy efficiency
  • Lift angle minimizes coolant carryout
  • Discharges at standard barrel height
Settings That Control Automatic Conveyor Operation
  • Setting 114 CONVEYOR CYCLE controls the interval at which the belt-style conveyor will start automatic operation during a cycle.
  • Setting 115 CONVEYOR ON-TIME controls the duration the belt-style conveyor) will run during automatic operation.
  • Setting 196 CONVEYOR SHUTOFF specifies the amount of time to wait without activity prior to stopping the conveyor.
NOTE: The operator doors must be closed to operate the belt-style conveyor.
Program Conveyor Operation
  • M31 starts the belt-style conveyor in the forward direction to remove chips.
    • Once started, and the machine is in cycle, the conveyor will run for the time specified in Setting 115 CONVEYOR ON-TIME, and then shut off.
    • Once started, and the machine is in cycle, the conveyor will restart after the time in Setting 114 CONVEYOR CYCLE, and run for the time specified in Setting 115.
    • While the machine is in cycle, you can start the conveyor by pressing the [CHIP FWD] button on the keyboard. Once started, Settings 114 and 115 have the same effect as described above.
    • If Setting 114 is set to zero, automatic auger operation will not occur.
  • M33 stops all automatic conveyor operation while in cycle.
    • Manually stop the conveyor while in cycle by pressing the [CHIP STOP] button on the keyboard. This stops all automatic conveyor operation while in cycle.
Manual Operation
  • Press the [CHIP FWD] button on the keyboard to start the belt-style conveyor in the forward direction to remove chips.
  • Press the [CHIP REV] button on the keyboard to start the auger belt-style conveyor in the reverse direction to clear a jam.
  • Press the [CHIP STOP] button on the keyboard to stop the belt-style conveyor.
Need More Information?
