15k Spindle (15K-40T)
Product Image
GET QUOTE
15,000-rpm Spindle
    CNY ONLY
High-speed spindle for Super Mini Mills
  • 15k Speed
  • 40 Taper
  • 15 hp Power
  • Belt Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 15,000-rpm belt-drive spindle provides high rpm at a very affordable price. Take advantage of the increased rpm to greatly increase spindle speed, and therefore feedrates, on soft materials and with small cutting tools. This system features a Haas-built cartridge spindle that is driven by the motor via belt. This provides a good combination of torque and rpm for a wide selection of machining operations. It is a great overall value.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • 50% faster spindle speed and feedrates than the 10,000-rpm spindle
  • Increased performance for 3D profiling
  • Increased performance when using small cutting tools and machining softer materials
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
