30k Spindle (30K-30T)
Product Image
GET QUOTE
30,000-rpm Spindle
    CNY ONLY
High-speed 30-taper spindle for VF Series and Mold Machines
  • 30k Speed
  • 30 Taper
  • 20 hp Power
  • Belt Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This BT30 taper belt-driven 20 hp (14.9 Kw) spindle features back-to-back ceramic angular contact bearings, and mid-point automatic air/oil lubrication for long, trouble-free life. This option also includes a side-mount tool changer. Note: Use only specified BT30 tooling without drive slots; using tooling with drive slots will result in damage to the tool changer and spindle. Do not operate the spindle at any time without a toolholder in the spindle taper.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
This option includes a 30+1 side-mount tool changer, which may be upgraded to a larger-capacity tool changer, if one is available on the host machine.
  • 3.5 times faster spindle speed than the 8100-rpm inline spindle
  • Ideal for small-diameter tools
  • Best performance for 3D profiling
  • Rigid Tapping is not available with this option
  • Through-Spindle-Coolant is not available with this option
  • Use only BT tooling without drive slots
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
