G-code, M-code, and Setting
Service Home G95 Live Tooling Rigid Tap (Face) (Group 09)
* C - C-Axis absolute motion command (optional)
F - Feed Rate
R - Position of the R plane
S - RPM, called prior to G95
W - Z-axis incremental distance
X - Optional Part Diameter X-axis motion command
* Y - Y-axis motion command
* Q - Peck Depth (always incremental)
Z - Position of bottom of hole
* indicates optional
G95 Live Tooling Rigid Tapping is an axial tapping cycle similar to G84 Rigid Tapping in that it uses the F, R, X and Z addresses, however, it has the following differences:
  • The control must be in G99 Feed per Revolution mode in order for tapping to work properly.
  • An S (spindle speed) command must have been issued prior to the G95.
  • The X Axis must be positioned between machine zero and the center of the main spindle, do not position beyond spindle center.
o60951 (G95 LIVE TOOLING RIGID TAP) ;
(G54 X0 Y0 is at the center of rotation) ;
(Z0 is on the face of the part) ;
(T1 is a 1/4-20 tap) ;
(BEGIN PREPARATION BLOCKS) ;
T101 (Select tool and offset 1) ;
G00 G18 G20 G40 G80 G99 (Safe startup) ;
G00 G54 X1.5 C0. Z0.5 (Rapid to 1st position) ;
M08 (Coolant on) ;
(BEGIN CUTTING CYCLE) ;
S500 (Select tap RPM) ;
G95 C45. Z-0.5 R0.5 F0.05 (Tap to Z-0.5) ;
C135. (next position) ;
C225. (next position) ;
C315. (last position) ;
(BEGIN COMPLETION BLOCKS) ;
G00 G53 X0 M09 (X home, coolant off) ;
G53 Z0 (Z home) ;
M30 (End program) ;
