G-code, M-code, and Setting
Service Home M96 Jump If No Input
P - Program block to go to when conditional test is met
Q - Discrete input variable to test (0 to 255)
R - A certain mechanism mode. R1 is for PP mode and R2 is for APL mode.
M96 is used to test a discrete input for 0 (off) and certain mechanisms status. Using the M96 with the Q code is useful for checking the status of automatic work holding or other accessories that generate a signal for the control. The Q value must be in the range 0 to 255, which corresponds to the inputs found on the diagnostic display I/O tab. When this program block is executed and the input signal specified by Q has a value of 0, the program block Pnnnn is performed (the Nnnnn that matches the Pnnnn line must be in the same program).The M96 sample program uses input #18 M-FIN INPUTExample:
O00096(SAMPLE PROGRAM FOR M96 JUMP IF NO INPUT) ;
(IF M-FIN INPUT #18 IS EQUAL TO 1 THE PROGRAM WILL JUMP TO N100) ;
(AFTER JUMPING TO N100 THE CONTROL ALARMS OUT WITH A MESSAGE) ;
(M-FIN INPUT=1) ;
(IF M-FIN INPUT #18 IS EQUAL TO 0 THE PROGRAM JUMPS TO N10) ;
(AFTER JUMPING TO N10 THE CONTROL DWELLS FOR 1 SECOND THEN JUMPS TO N5) ;
(THE PROGRAM CONTINUES THIS LOOP UNTIL INPUT #18 IS EQUAL TO 1) ;
G103 P1 ;
N5 M96 P10 Q18(JUMP TO N10 IF M-FIN INPUT #18 = 0) ;
M99 P100(JUMP TO N100) ;
N10 ;
G04 P1. (DWELL FOR 1 SECOND) ;
M99 P5 (JUMP TO N5) ;
N100 ;
#3000= 10(M-FIN INPUT=1) ;
M30 ;
Using the M96 with the R code allows user to run a G/M-code program after M96R1 which will check if the pallet mode is ON to perform a certain function for example a wash cycle program. This is useful on a pallet pool machine if you want to clean the receiver before loading the next pallet while the machine is in pallet mode.The following program is an example on how to use the M96with a R code to run a wash cycle if the machine is in pallet mode.
O00097(SAMPLE PROGRAM FOR M96 R1 JUMP IF PP MODE IS NOT ON);
(MACHINE OPERATIONS);
N5 M96 P100 R1 (CHECK PALLET SCHEDULE - JUMP TO N100 IF NOT IN PALLET MODE);
M50P0 (UNLOAD PALLET FROM MACHINE);
(G/M CODE BLOCKS FOR PALLET POOL WASH CYCLE - AS EXAMPLE);
N100M199 (LOAD NEXT PALLET IF IN PALLET MODE, OTHERWISE M30);
