G-code, M-code, and Setting
Service Home 36 - Program Restart
When this setting is ON, restarting a program from a point other than the beginning directs the control to scan the entire program to make sure that the tools, offsets, G- and M-codes, and axis positions are set correctly before the program starts at the block where the cursor is positioned.
When Setting 36 is ON, an alarm will be generated if the program is started on a line of code where Cutter Compensation is active. It is mandatory to start the program before a line of code with G41/G42 or after a line of code with G40.
NOTE
The machine first goes to the position and changes to the tool specified in the block before the cursor position. For example, if the cursor is on a tool change block in the program, the machine changes to the tool loaded before that block, then it changes to the tool specified in the block at the cursor location.
The control processes these M-codes when Setting 36 is enabled:
M08 Coolant On
M09 Coolant Off
M41 Low Gear
M42 High Gear
M51-M58 Set User M
M61-M68 Clear User M
When Setting 36 is OFF, the control starts the program, but it does not check the conditions of the machine. Having this setting OFF may save time when running a proven program.
