6 - HBF - 12 - Maintenance
Haas Bar Feeder 12 - Operator's / Service Manual
  • 0 - HBF - 12 - Table of Contents
  • 1 - HBF - 12 - Introduction
  • 2 - HBF - 12 - Legal Information
  • 3 - HBF - 12 - Safety
  • 4 - HBF - 12 - Installation
  • 5 - HBF - 12 - Operation
  • 6 - HBF - 12 - Maintenance
  • 7 - HBF - 12 - Troubleshooting
  • 6.1 HBF - 12 - Maintenance
  • 6.2 HBF - 12 - Service Parts List
HBF - 12 Maintenance Schedule
Revision B - 06/2026
Updated
The HBF - 12 requires little regular maintenance for optimal operation. This page shows the recommended maintenance intervals.
 Warning: Press [POWER OFF] on the lathe before you do maintenance tasks.
Maintenance Item Interval Action
Exterior Daily Clean
FRL System (Pneumatic) Daily Check for leaks and pressure. Check oil level
Channels and collet Weekly Visual inspection and checl for smooth rotation
Anti-Vibration Device Weekly Visual inspection
HPU Weekly
Oil level inspection (Ensure oil is changed once per year)
(Requires 11.75 gal (44L))
PN : 93-5656: OIL, 1 GALLON ISO 68
Linear Guide Weekly Clean
Monthly Grease
Rack gear Weekly Clean
Monthly Grease
Oil pump Monthly Verify oil flow throw the lines and inspect for any blockages/kinks
Chain Monthly Clean and grease
Quarterly Check tension
Drive belt Monthly Check tension and inspect for any cracks/wear
HBF - 12 - Service parts List
Revision C - 06/2026
Sub-Assembly Exploded View
HBF - 12
  1. Static Opening Adjustment
  2. Dynamic Opening Adjustment
  3. Opening Indicator Gauge
  4. Oil Supply Valve
  5. V-type Anti-Vibration Jaws
HBF - 12
  1. Clamping Jaws (93-5446)
Part Number DESCRIPTION
93-5519 HMI W/ PROGRAM HBF12
93-5518 PLC W/ PROGRAM HBF12
93-5517 PLC MODULE HBF12
93-5516 DIGITAL/ANALOG CONVERTOR FOR PLC HBF12
93-5515 MEMORY CARD HBF12
93-5474 PROXIMITY SWITCH HBF12
93-5436 REMOTE CONTROLLER HBF12
93-5451 AIR REGULATOR HBF12
93-5440 PRESSURE SWITCH HBF12
93-5441 ANTI-VIBRATION DEVICE ACTUATOR HBF12
93-5473 PUSHER SERVO MOTOR HBF12
93-5454 SOLENOIDS HBF12
93-5453 SOLENOID VALVE SET
93-5442 METAL LEVELING FEET HBF12
93-5443 PLASTIC LEVELING FEET HBF12
93-5452 HYDRAULIC PUMP HBF12
93-5445 MAIN POWER SWITCH HBF12
93-5444 BAR HEIGHT ADJUSTOR HANDLE HBF12
93-5446 BAR CLAMPING JAWS HBF12
93-5447 HYDRAULIC FLUID SIGHT GLASS HBF12
93-5450 DOOR STRUTS (SET OF 2) HBF12
93-5438 UPPER SERVO BELT HBF12
93-5437 LOWER SERVO BELT HBF12
93-5521 SHUTTLE MOTOR HBF12
93-5489 BREAKER GEAR BOX HBF12
93-5491 THERMAL RELAY 3RU2116-0EB0 HBF12
93-5490 THERMAL RELAY 3RU2116-1AB0 HBF12
93-5478 BREAKER 3P10A LS HBF12
93-5477 MAGNETIC CONTACTOR HBF12
93-5476 AUXILIARY CONTACTOR HBF12
93-5475 CONTACTOR INTERLOCK HBF12
93-5514 SPARK QUENCHER HBF12
93-5513 AMPLIFIER HBF12
93-5512 POWER SUPPLY 12V HBF12
93-5511 POWER SUPPLY 24V HBF12
93-5895 DOOR LIFT HANDLE HBF12
93-5958 SAFETY SWITCH HBF12
93-5903 DOOR LIFT HINGES HBF12
93-6203 BAR RING PUSHER 2" HBF12
